08-22-2013, 07:23 AM   #16
QuoteOriginally posted by sTi Quote
WB setting on the camera is not "irrelevant", as your Raw converter uses the camera white balance setting as its starting point.
You could compare the embedded JPG preview images with what you get in your programs. If there is a large discrepancy between the JPGs and what you get from Raw conversion software (with WB set to "camera"), the problem is with the software (probably bad color profile or wrong interpretation of white balance values) and not bad calibration of your camera.
The embedded JPGs show the exact same weird white balance as the three raw convertors that I have tested. As mentioned previously, only RPP gets the WB right. It is an odd little program with very few features that does certain things very well.
Rob
08-22-2013, 07:43 AM   #17
sTi
QuoteOriginally posted by robgo2 Quote
Rob
So does RPP ignore the WB values set in-camera and instead uses an automatic WB detection of its own?
08-22-2013, 01:04 PM   #18
I believe that is correct.
Rob
Edit: RPP was the raw convertor that I used for my best images for about 2 years. It is Mac only and has only basic features, The quality of its raw conversions is excellent, with superb white balance but somewhat weak highlight recovery. I have since migrated to Photo Ninja for virtually all of my work. Awesome program. Those who might enjoy playing with a quirky program that gives very good results should give RPP a try. It's free.
08-22-2013, 01:11 PM   #19
Problem solved!
I spoke by telephone with Ricoh-Pentax technical support today. The technician had no idea what was causing the white balance problem, but he suggested that I reset the camera to its default settings in the Setup menu (under the wrench icon). That fixed it. Images are no longer yellow-orange. So, the problem was with the camera, not the software, and did not require any major work to resolve it.
Thanks to all who tried to help.
Rob
08-22-2013, 07:29 PM   #20
Aha. So somewhere in the guts of the camera (and its million adjustable settings) a WB mal-adjustment was lurking.
A useful reminder about the value of resetting to a vanilla config sometimes.
balance, camera, convertor, dslr, files, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Weird white balance issue on my K-5 with flash Codazzle Pentax K-5 3 01-02-2013 04:04 PM
K-5, Adjusting White Balance Manually, pp 208-209 Joe Rice Visitors' Center 5 09-02-2012 10:52 AM
Manual white balance problems on K5 2grahamb Pentax K-5 10 09-29-2011 01:06 AM
cold white balance in K-5 HanSch Pentax K-5 5 08-30-2011 01:23 PM
K-5 White Balance problems conroy11 Pentax K-5 7 12-25-2010 07:38 AM
All times are GMT -7. The time now is 03:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
