Originally posted by krp Today I was taking a picture on the edge of a creek. My tripod wasn't in the most stable position. There was water rushing around the legs and it was resting on slippery rocks. I looked away for 2 seconds, and then SPLASH! I quickly reached down and pulled the camera up. I ended up bending a tripod leg which was caught under a rock. But the K-5 still works just fine. Even though the lens wasn't waterproof, no water got into the body. Now my only problem is drying out the lens. There are drops of water and fog inside the Tamron 17-50mm f2.8 lens. I just bought a bag of rice and I have some desiccant packs. Has anybody else dried out a lens this way? I'm hoping it won't take too long since I would like to use the lens Monday night.
Hi KRP, sorry for the accident, but these things do happen. Try soft rubber shoes for the tripod legs next time. You already have had some good advice. A 40 watt bulb over the lens and camera with a fan wafting air softly over them should help once you are done with the silica gel and other stuff. Please don't hurry it. Even a little moisture will blow the mother board in the lens and the camera. Do separate the camera and the lens.
Good Luck and Regards.
