09-10-2013, 12:21 PM   #1
new K-5 II setup
Hi all, so after FedEx decided to leave my new camera in their warehouse for an extra 3 days, I finally have it! Very excited to begin shooting. Was curious if there were any suggestions for the initial menu settings I should select? I shoot RAW almost exclusively, mostly landscape and nature.
Thanks in advance!
09-10-2013, 12:58 PM   #2
TER-OR's Avatar
I'd set up a FAST SHOT user mode. Disable SR, in-camera processing like lens correction and highlight correction, set in TAv mode, center focus and spot metering, high-speed continuous recording mode with shutter speed 1/350 f8ish and you'll have a camera you can fire machine-gun mode when those critters are cavorting. Essentially remove as much processing and "thought" from the camera as you can. You'll get 6fps easily.
I did try originally to play with some of the jpeg processing, but found Natural was more pleasing to me. I shoot RAW+, and will post either from jpg or processed RAW depending on the use and quality required.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5
New Pentax K-5, K-5 II & K-5 IIs Adobe Camera Profiles PentaxGuyUK Post-Processing Articles 7 12-04-2014 05:02 AM
Flickr not differentiating between K-5, K-5 II, and K-5 II s Corby Pentax K-5 5 04-27-2013 04:05 PM
New Firmware For K-01, K-30, K-5, K-5 II, K-5 IIs, K-r Adam Pentax News and Rumors 63 02-18-2013 02:04 PM
K-5 ii vs K-5 iis comparison with higher sharpness in K-5 ii kataria0 Pentax K-5 62 12-22-2012 10:12 PM
New Menu item on K-5 II / K-5 IIs apac Pentax K-5 8 10-31-2012 05:55 AM
All times are GMT -7. The time now is 05:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
