09-25-2013, 08:31 PM   #1
Macro Photography
I recently bought a Pentax SMC f3.5 100mm macro lens. On the barrel it says that the closest it can get 1:2 on 35mm so what would the ration be on a Pentax K5.
Can anyone help.
09-25-2013, 08:38 PM   #2
It will still be 1:2. You'll be the same distance away from the subject with a K5 or film. The K5 photo, compared to film, will appear to be more zoomed in because the APS-C sized sensor is smaller than film, but focusing distances don't change.scale
09-25-2013, 11:12 PM   #3
QuoteOriginally posted by DeadJohn Quote
Thanks for that would a Pentax 100mm dental macro be 1:1.
To get to 1:1 I have to attach my Raynox 250 or tubes.
09-26-2013, 02:01 AM   #4
topace's Avatar
The pentax A 100mm dental macro seems to be a version of the 100/4, which also only does 1:2.
You can of course use tubes to get it closer. Also, the dental version came with its own closeup filters. Those are probably very good.
09-26-2013, 02:55 AM   #5
Fogel70's Avatar
Didn't the Pentax 100/3.5 Macro come with a matched screw-on macro adapter that gave 1:1?
09-26-2013, 05:19 AM   #6
bluestringer's Avatar
You don't need 1:1, just crop. Pentax K7 / Pentax 100mm f4 Macro...........
09-28-2013, 08:35 PM   #7
I have bought a reversing ring so I can either put on my 28mm or 20mm. If I attach my 20mm to the front of the macro I can fill the viewfinder with a number on a ruler.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, macro, pentax, pentax k-5
Flash for macro photography catastrophe Flashes, Lighting, and Studio 31 10-13-2013 04:41 PM
Micro - Not Macro Photography LaurenOE Photographic Technique 17 07-15-2013 12:15 AM
Macro insect photography metaphiston Photographic Technique 8 06-13-2012 01:59 AM
Mini flash for macro photography trco Flashes, Lighting, and Studio 8 11-14-2011 01:51 PM
Options for macro(or near macro) photography dinneenp Pentax SLR Lens Discussion 4 05-09-2010 01:26 PM
All times are GMT -7. The time now is 09:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
