Originally posted by JJJPhoto Does the bottom "clip" on the Hoodeye (the plastic piece that helps prevent it from sliding up) fit on the K-5 or does that have to be removed as well?
Yes, the bottom locking tab needs to be shaved to about half of its vertical dimension to allow the tab to snap in and seat itself fully. I trimmed the side 'channels' with a sharp utility knife and the tab with a fine-pitched rectangular file.
The eyecup at Amazon seems to be similar to the Hoodman.
I use the larger eyecup regularly. The only drawback is that it partially obscures the rear LCD screen, but I can peer up under it to see menu selections and get a satisfactory view of displayed images.
- Craig
