10-02-2013, 10:51 AM   #1
maxk7dish's Avatar
K5 iis - Compatibility issue with Yongnuo 560 or hotshoe issue?
Recently I purchased 2 Yongnuo 560s and some triggers off the marketplace as a starter flash kit. Everything seemed to work fine in isolation - the flashes both work normally and fire remotely when connected to the trigger system (aputure trigmaster). As soon as I try to put one of the flashes on my K5IIs directly mounted on the hotshoe, however, nothing works. With one of the flashes, it will fire once and then the flash locks up. None of the buttons on the flash work until I remove it from the hotshoe. The other flash, which worked before, no longer works at all now. It will turn on normally, but then as soon as it is connected to anything (triggers or k5), it turns itself off. Considering the fact that both flashes worked fine with the triggers before I connected them to my k5 iis, I can't help but wonder if something is wrong with my hotshoe. I've taken my camera out before in rain with no hotshoe cover.. could weather be the culprit? Nothing else on my camera is abnormal. Have any of you run into similar issues with the K5 IIs and Yongnuo 560?
10-02-2013, 01:54 PM   #2
fs999's Avatar
Solution : mounted YN-560 flash problem
10-02-2013, 06:43 PM   #3
maxk7dish's Avatar
Ahh, thanks, I had seen this thread before a while ago (before I owned the YN560, incidentally) and couldn't find it again.
issue with yongnuo
yongnuo 560 III with K5 IIs dltorre Troubleshooting and Beginner Help 5 08-25-2013 06:59 PM
K5 IIs Issue chrisan Troubleshooting and Beginner Help 7 08-12-2013 09:55 AM
What's up with my new Yongnuo Speedlite YN 560-II...no hotshoe mount? Edgar_in_Indy Flashes, Lighting, and Studio 13 04-16-2013 11:49 AM
Freeze Issue Redux - K5 IIs JBWPhoto Pentax K-5 25 04-01-2013 01:57 PM
Issue with K5 IIs preorder photovast Pentax K-5 11 10-29-2012 01:04 AM
All times are GMT -7. The time now is 10:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
