Originally posted by bscott Thanks so much the reply and my lens does use an adaptol so I would need to check how it would work on the K5. Do you know if I would need to use stop down meter reading on the K5?
Is the adapter you are using now a K or KA version? Does the PZ-1 you are using it with now set the aperture or do you have to set the aperture manually?
If the adapter has the 'A' setting you will not have to use stop down metering. KA adapters are pricey, but may be worth it for convenience.
