View Poll Results: Would you like Pentax to upgrade to the K-5 III?
Yes, a new K-5 III would be great! 2531.65%
No, keep the K-5 II in production. 3037.97%
No, ditch the K-5 II, there is no room for an extra body in the camera line-up. 2430.38%
Voters: 79. You may not vote on this poll
10-09-2013, 12:53 AM   #1
Banned
K-5 iii
Should Pentax come with an update for the Pentax K-5 II in spring to make the cameraline more complete? As off now there are 4 dslr's in line with K-500, K-50, K-5 II and K-3. Pentax could drop or fase out the K-5 II, but could also run the line off 4 camera's (maybe topping it with a FF K-1).
K-5 III
  • Keep the current body from K-5 II and the D-GB4 grip.
  • Keep the 16 megapixel sensor.
  • PRIME III processor.
  • Safox 11 AF-module.
  • Framerate of 7 fps with the 100k shutter.
  • One SD card.
  • USB 3.0 port instead of USB 2.0
  • New 86k RGB metering system.
  • Sensor only with AA-filter.
  • Videospecs from K-3, but no headphone jack.
  • Pentaprism as in the K-5 II.
I think that would be a great camera in line-up. Basicly only updating the electronics inside with the PRIME III, Safox 11 AF-module, new metering system and USB 3.0 port.
Do you think this would be a good idea for expanding the camera line-up or just be a bad way to undercut the K-3 market?
10-09-2013, 12:57 AM   #2
QuoteOriginally posted by RonHendriks1966 Quote
K-5 III
  • One SD card.
I don't think many would complain about this, especially if it were priced at $999 (halfway between the K-50 and K-3).
On the other hand, they could just as well keep the K-5 II in production.
IMO they will take the usual route and simply discontinue the K-5 II, however. Since they current have 3 other bodies, they should be in better shape than they've been in a long time!
10-09-2013, 01:51 AM   #3
RobA_Oz's Avatar
You forgot to mention a yellow-bodied version, Ron!
I'm not sure what market segment this proposal would address. The K-50 is a very capable camera, probably lacking only the top LCD and body material of the K-5. I recognise the attraction of keeping the same basic underpinnings from a successful predecessor, but there has to be a recognisable market for it, and I think the K-50 would probably undercut it, especially if some of the K-3 technology filters down to the next K-50 iteration.
Personally, although it's not in the same product stream, I think Pentax would be better putting their efforts into a 2nd generation K-01, preferably with an EVF built into the body, and definitely with some of the K-3 technology. I don't think I'd get an argument from you on that one.
10-09-2013, 02:18 AM   #4
calsan's Avatar
I see no reason to get rid of it at this point in time. It still makes sense as a camera for people who just want still photography features. It's also a great price now and it's always good to have choice. Even though the price of the k-3 is quite reasonable, the price jump from the K-5ii to the K-3 is currently enough to get a lens.
10-09-2013, 05:29 AM   #5
Banned
Wow we are evening out at the moment with all three choices on a same level.
10-09-2013, 06:00 AM   #6
TenZ.NL's Avatar
That`s simply put a K5II with Prime III... or, depending how you look at it, a cutdown K3.
I know I would fork out the extra €300 for the K-3 and I guess a lot of people probably would also (If the price not allready got lower).
10-09-2013, 06:18 AM   #7
Safox 11 AF-module.
I like an upgraded K5III, KEEPING 16MP SENSOR. Maybe not the same one as on K5, but newer one with better high ISO noise control. not sure if pentax can find a new 16 APC-S sensor though.
But I would like to see the 25 AF-module.
And why do you not like the Pentaprism on K3? a brighter viewfinder is great!
10-09-2013, 06:23 AM   #8
LaurenOE's Avatar
Interesting.
The K5II is a great camera, and I could see it still being in production as it's a better camera than the K50/500 and it can live in the price point below the K3.
That's a good point. Let's see what Ricoh does.
10-09-2013, 06:28 AM   #9
krebsy75's Avatar
The only con with the K-3 is increased size. I think APS DSLRs should be as small as possible Hence, my prelim preference for the K-5II.
10-09-2013, 06:50 AM   #10
monochrome's Avatar
Just keep the current K-5 in production, making whatever FW updates are possible given hardware limitations.
10-09-2013, 07:22 AM   #11
crewl1's Avatar
Agreed.
As much as i love the K-5 form factor I feel the engineering resources should be focused on shoving the FF sensor into the larger chassis and developing new lenses.
10-09-2013, 07:29 AM   #12
monochrome's Avatar
QuoteOriginally posted by crewl1 Quote
Agreed.
K5II/s is a spectacular camera in its own right, especially at a lower price point. Allow consumers to decide to "reach" for the K-3 - don't tempt them to compromise by moving new tech down to a K5III. Work on the shutter(s) and flash for the K-1 and 645DII. Incrementally improve your, then, quite competent base technologies.
That is the Ricoh way.
10-09-2013, 07:39 AM   #13
TER-OR's Avatar
Essentially won't this be the K-30, the mid-range version of the K3? Oops, they already used that...screwing up their numbering scheme.
I guess they could do K-300, an entry-level version. I'd rather see them use the K3 format and make reduced-cost versions. I won't buy one, but it might make sense to leverage the R&D and production investments.
Will we see a K-03, the mirrorless version? That might be very interesting.
The K3 is the camera I hoped they'd release. I'm already seeding the idea of upgrade at home - going for the soft sell, since my K5 is still darn good.
10-09-2013, 07:48 AM   #14
I like the K5III idea !
10-09-2013, 06:39 PM   #15
Banned
QuoteOriginally posted by grahame Quote
I like the bigger pentaprism, but the general idea to this K-5 III is to update the internals and not developing a new body.
camera, dslr, k-3, k-5, k-5 ii, k-5 iis, k5, pentax, pentax k-5, port, usb
New Firmware for K-500, K-50, K-5 II, K-5 IIs, K-5, K-30, K-01, K-r, and 645D is out Adam Pentax News and Rumors 60 09-16-2013 05:46 AM
Pentax K-5 and Yongnuo 560 III wmich Troubleshooting and Beginner Help 6 07-24-2013 12:47 PM
For Sale - Sold: K-5, K300/4, Vanguard 43, Kenko 2xTC, Quant 28-90 & Macro FF, TR-III, Grip, Filter Docrwm Sold Items 12 05-31-2013 08:59 PM
For Sale - Sold: Pentax TR Powerpack III and K-AC50 A/C adapter for K-7, K-5, K5II arm_jstp Sold Items 2 01-23-2013 08:29 AM
K-5 vs. Nikon D4 and Canon Mark III oeriies Pentax K-5 & K-5 II 14 08-17-2012 06:20 AM
All times are GMT -7. The time now is 04:15 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
