10-28-2013, 07:42 PM   #16
I was using a screw mount SMC 55mm f1.8 lens for these particular shots so I was pressing the green button to set metering. I have also had the problem using K mount A* lenses. It is pretty rare but it does happen once in awhile. Firmware is the latest version. I had it happen on my K5 a few times too.
10-28-2013, 08:00 PM   #17
RobG's Avatar
QuoteOriginally posted by gaweidert Quote
Maye try Digitalis' suggestion and set a fixed colour temperature and see if the problem goes away? Do you shoot RAW - and if so can you check whether the raw data shows any difference?
10-28-2013, 11:55 PM   #18
Digitalis's Avatar
QuoteOriginally posted by RobG Quote
Interesting that you have it set as low as 5000K. Isn't that a bit low for normal daylight?
I'm shooting RAW DNG - I use a fixed white balance of 5000K as a point of reference on all my cameras. you're right : It is set a bit low for daylight - but I prefer the extra warmth it provides and It is simpler with my particular workflow to leave it at 5000K - rather than having the WB settings change from shot to shot, that is just unprofessional and messy IMO.
10-29-2013, 02:33 PM   #19
RobG's Avatar
Fair enough. I was just curious.
camera, dslr, exposure, fault, focus, k-5, k-5 ii, k-5 iis, k5, mode, pentax k-5, shutter
ME Super exposure fault? scottbmxer Troubleshooting and Beginner Help 10 10-23-2013 02:16 AM
Long exposure shots, ND filters and multi-exposure averaging rrstuff Photographic Technique 17 10-19-2013 12:50 PM
Nikon fault ? chromo Non-Pentax Cameras: Canon, Nikon, etc. 3 08-10-2013 03:47 PM
Camera fault Sam Wareham Visitors' Center 3 12-25-2012 03:55 PM
K7 AF Fault? RobG Pentax DSLR Discussion 11 02-13-2012 09:20 AM
All times are GMT -7. The time now is 08:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
