Originally posted by carrrlangas are you using auto white balance or the specific one for tungsten light? If itīs the latter, take a look at option 10 in menu C 2, "White balance adjustment range", where you can choose between Auto (automaticaly adjusts white balance even when light source is specified) and Fixed.
If both cameras are in AWB, make sure they are both without any corrections. (click WB button "left arrow", then "right arrow" to access color tunning and green button to reset it)
Also, from exif data, metering mode is different between the cameras, and so thereīs 1/2 stop difference in shutter speed.
the body B was in spot metering and the other in centre weighted i will see if that caused the WB difference
