11-06-2013, 06:57 PM   #1
noelpolar's Avatar
K5 II played up on my holiday to China
I just got back from 2 weeks in China. About midway through the trip, on power up my K5 II came up with a screen that prompted me to set the focal length of the lens attached. The auto focus didn’t work and the aperture of the lens didn’t work (stayed fully open).
It was as though the lens and the camera body wasn’t talking to each other. I then tried two other lenses with the same result (all newish auto focusing lenses; lens/camera contacts seemed clean/functional).
Anyway, I continued to take photo’s by manually setting all relevant parameters ( set zoom length, power on camera, set focal length, set aperture to 2.8 on camera, then choose shutter speed and ISO to get reasonable exposure, then manually focus (got lots of great shots still!) This camera state was consistent over the next 4-5 days.
Later I noticed that once in a while when the camera was switched on it seemed to work ok for a few shots…..then it reverted to it’s faulty state as per above. seems like a loose connector/contact, dry joint etc?
So back it goes to Pentax to see whats going on. https://www.pentaxforums.com/forums/images/smilies/hmm.png
11-06-2013, 07:16 PM   #2
Eric Auer's Avatar
Dirty contacts.
Try a rubber eraser to clean them But be damn careful not to get any residue inside the camera.
I did mine upside down VERY gently.
11-06-2013, 07:32 PM   #3
You can also use some high purity rubbing alcohol (90%+) and a swab. It is very common with every modern interchangeable lens camera.
aperture, camera, dslr, focus, k-5, k-5 ii, k-5 iis, k5, length, lens, lenses, pentax k-5
Adapter for using Nikon mount lens on my K7/K5 II screwmountdude Pentax SLR Lens Discussion 6 10-14-2013 09:13 AM
Starting to worry that my K5 is messed up Sig0431 Troubleshooting and Beginner Help 5 04-15-2013 12:38 AM
Advice on what lenses to take on outdoor holiday trip JohntheThird Pentax SLR Lens Discussion 22 02-24-2013 06:51 AM
Lens compatibility confirmation: Will my MZ-30 lenses work on K5 or K5 II? RachaelJamess Visitors' Center 4 11-22-2012 10:23 AM
Advice needed for using K5 on a camping holiday symphony1010 Troubleshooting and Beginner Help 8 04-27-2012 08:31 AM
All times are GMT -7. The time now is 02:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
