11-09-2013, 02:45 AM   #1
auto zoom on playback?
When using playback to compare the focus quality on a number of shots of the same subject taken in succession, is it possible to set and hold a particular zoom level at the first shot so that zoom is maintained for playing back all the subsequent shots?:
11-09-2013, 04:44 AM   #2
chromo's Avatar
Yep...Set your zoom level with the rear scroll wheel, then cycle through your photos with the front scroll wheel. The zoom will be maintained
11-09-2013, 05:25 AM   #3
QuoteOriginally posted by chromo Quote
Thanks Chromo!!
11-09-2013, 06:08 AM   #4
You can also set a default zoom level for playback (Play button > Menu 1 > Quick zoom) which will apply a certain zoom ratio by default when you initially zoom into an image via the rear scroll wheel [p-236 K-5 manual]. That ratio will then be maintained as you scroll through your images via the front wheel.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Playback menu question on 645D Newmoon Pentax Medium Format 6 04-10-2012 07:30 AM
No sound on playback Copper top Visitors' Center 3 01-08-2012 04:47 PM
K-m tip: Playback quick-zoom-out feature dave9t5 Pentax DSLR Discussion 3 05-04-2009 09:33 AM
Auto zoom on AF-540FGZ question dws1117 Pentax Camera and Field Accessories 2 12-15-2008 09:53 AM
somehow my playback zoom was locked out? attack11 Pentax DSLR Discussion 2 02-14-2008 12:34 PM
All times are GMT -7. The time now is 01:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
