11-12-2013, 05:16 AM   #1
Wanting to upgrade from K-5 to K-5ii/iis - Have some questions
Hi
Ive read that the focus accuracy of the K-5ii is better than the original one so I want to upgrade to it because my FA 43 need different AF adjustment depending on the situation. Maybe the 2.8 sensor will work better?
How is the optical viewfinder in K-5ii vs K-5? My K-5s viewfinder have alot of reflections so I cant see through it clearly. Does the K-5ii have the same one?
11-12-2013, 06:31 AM   #2
LaurenOE's Avatar
QuoteOriginally posted by striker_ Quote
Reflections in the viewfinder?
11-12-2013, 06:59 AM   #3
Digitalis's Avatar
QuoteOriginally posted by LaurenOE Quote
I think this person wears glasses, in which case the viewfinders are practically identical. So there won't be any improvement there.
11-12-2013, 07:02 AM   #4
stormtech's Avatar
For the AF issue, I went through the same thing - take a look here:
https://www.pentaxforums.com/forums/115-pentax-k-5/218145-k-5-iis-focus-consi...-vs-k-5-a.html
11-12-2013, 07:47 AM   #5
Gray's Avatar
K-5II AF is everything the K-5 AF should have been. Night and day difference. You won't be disappointed by the K-5II/s.
11-13-2013, 04:34 AM   #6
Thanks for the replies. The reflection on the viewfinder comes from not having my eyeball glued on it blocking all light from the sides. Yeah I wear glasses so the distance becomes greater. Using the OME53 helps a little but using it with glasses vignettes and the view feels weird. Some sort of distorted.
I think I will go for the K-5iis because I have a NEX 5n with same sensor already. That would help taking moirefree pictures. Perfect combo.
camera, dslr, k-5, k-5 ii, k-5 iis, k-5ii, k5, pentax k-5, viewfinder
Would you pay $350 to upgrade from K-5 to K-5II? chesebert Pentax K-5 18 07-16-2013 06:36 PM
Pentax K-5 IIs Upgrade - Manual Flash Questions A-PeeR Pentax K-5 6 02-24-2013 02:42 AM
Upgrade to K-5ii or iis ? - answering the unanswerable Santoku Pentax K-5 21 02-05-2013 09:22 PM
How best to de-blur k-5/k-5II users to match k-5IIs close-enough Pentax K-5 11 12-03-2012 02:14 PM
Some K-5 IIs samples to download foto guy Pentax K-5 12 11-07-2012 11:16 AM
All times are GMT -7. The time now is 11:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
