01-16-2014, 05:03 PM   #1
Query: Pentax K-5 II AF
Hi
Well! I did not take the advise of some of the senior members of this forum and just like a blonde got my makeup kit which I don't know how to use well. (Makes me look like a drag queen - Every now and then). - Such an advanced camera and a cheap kit lens. I should have listened to veterans telling me to spend on Lens. But well!
So I understand the camera quiet well now. Took about 4000 pictures from it. I am still using the poor man's 18-55 mm Kit lens.
I have a few questions related to AF.
1. How do I get everything into focus (What is the best technique - Landscape)? I see distant objects (Near Horizon - In Pixel peeping - Really as blurred or Burned out) - Is it my cheap lens (18-55 kit lens)?
(P.S. I have tested between F8 and F11. My F8 produces sharper results - No seriously It does. Better than F13 - Day light shooting that is). I keep the AF to Center Focussed and sometimes when putting my subject in focus along with SEL. The Auto AF chooses whatever is in the front and is stupid.
ALSO - Basically the idea - The best way to get my girl friend and the beautiful hill in the background all in focus.
2. Is there a way to group those AF points? Like in Canon 7D? (If not I hope future Firmware by Ricoh does it).
Cheers!
01-16-2014, 05:44 PM   #2
JimmyDranox's Avatar
Simple. Use the hyperfocal distance. What is this? If you put the subject at half of this hyperfocal distance, everything is behind it will be in focus. How can you find out this distance? There are on net a number of hyperfocal calculator. Anyway, this distance depends, of course, by the focal distance of your lens, the smaller, the closer the distance, by the aperture, (I think you know this), and by the size of the sensor.
Later I will try to find a good HF calculator.
01-16-2014, 07:08 PM   #3
QuoteOriginally posted by Deedee Quote
You mean use more than one at a time? There's an auto area (11-point or 5-point) mode on the K-5, but not much more than that.
01-16-2014, 09:44 PM   #4
sterretje's Avatar
Read up on depth-of-field. Hyperfocal distance was already mentioned, here is an online calculator: Online Depth of Field Calculator
Select camera, select focal length and aperture. For 18mm and f/9.5, the hyperfocal distance is approximately 2 meters. So focus on something 2 meters away and everything from 1 meter to infinity will be in focus. If you have a non-L version of the kit lens, it has a distance scale; use manual focus, set the lens to two meters and you're ready to go.
You can also fill in a subjet distance and it will tell you what will be in (perceived) focus.
The leaf on a tree a mile away might only be one pixel; so you will not be able to see detail in the background. If you expect that kind of detail, you will be disappointed. Your eye will also not see it, by the way
Burned out is a matter of exposure; you will always have to compromise somewhere. If the subject is properly exposed, a background might be over or under exposed. In your example, you might get the best results by using matrix metering and/or using exposure compensation.
Better than F13
I don't know much about the subject of diffraction, but at f/13 you will probably run into it. As a result photo will be less sharp at f/13 (compared e.g. to f/8).
Not familiar with a 7D so can't really tell you. But if you expect that to help you, be aware that the camera can only focus at one (and one only) distance.
I hope this helps a little.
01-17-2014, 04:50 PM   #5
QuoteOriginally posted by JimmyDranox Quote
QuoteOriginally posted by sterretje Quote
Gentlemen, Thank you, this forum indeed is a great place for people like us - Pentaxians specially. Atleast we can enjoy film era photographers and digital alike. I would read about it more. I just wanted to leave a note of thanks.
It really means a lot to me, when someone takes their time in explaining these bits and pieces. Thank you so much.
Cheers!
af, camera, dslr, f8, focus, k-5, k-5 ii, k-5 iis, k5, kit, lens, pentax k-5
Flickr not differentiating between K-5, K-5 II, and K-5 II s Corby Pentax K-5 5 04-27-2013 04:05 PM
K-5 ii vs K-5 iis comparison with higher sharpness in K-5 ii kataria0 Pentax K-5 62 12-22-2012 10:12 PM
Pentax K-5 II & IIs AF area expansion Malsi Pentax DSLR Discussion 9 11-15-2012 01:52 AM
First PENTAX K-5 II Test Video (AF Speed)!!! ogunturkay Pentax K-5 12 09-18-2012 03:40 PM
Pentax DA 18-55 II query matt_not_andrew Pentax SLR Lens Discussion 20 03-05-2012 10:01 PM
All times are GMT -7. The time now is 03:32 AM. | See also: NikonForums.com, part of our network of photo forums!
