01-19-2014, 01:27 AM   #1
Image Stabilization-Why Turn It Off When Mounted On Tripod
Hello-The instruction manual for both my Pentax K20D as well as the K-5 II says to turn off the image stabilization when mounting the camera on a tripod. However, nothing further is said in either manual. What are the consequences of NOT turning it off?
I have left the image stabilization on for all tripod mounted photos and haven't noticed any difference in the quality of the photos or heard the stabilization trying to work. Is it hard on the camera? Does the camera keep trying to stabilize when there's little, if any, camera movement? Does it somehow damage the camera or the photos?
Would like a further explanation and comments from Pentax tech.
Thanks!
StrasburgBarry
p.s. I always use a wireless remote when the camera is on a tripod.
01-19-2014, 01:37 AM   #2
i83N's Avatar
yes it will try to stabilize so you will loose sharpies of shot.
01-19-2014, 01:55 AM   #3
Billy Joe's Avatar
If you are using the 2 or 10 second timer, it automatically turns off IS...
But if you are on a tripod and just pushing the shutter, then the camera SR is moving the sensor slightly trying to correct a non-existent shake... so that induces micro-movement
01-19-2014, 01:57 AM   #4
Alcazar's Avatar
When you use a remote control or timer, the camera deactivates the SR automatically.
If i remember right, it is better to have the SR off because in that situation the SR can do more harm than good. Don't remember why exactly but there's a technical explaination for this
01-19-2014, 04:41 AM   #5
IMHO, SR should always be off *until* you need it.
01-19-2014, 10:58 AM   #6
johnyates's Avatar
QuoteOriginally posted by StrasburgBarry Quote
Then you always have SR off when you shoot on a tripod.
01-19-2014, 08:47 PM   #7
This is what happens with the tripod mounted K-01 when SR is turned on in movie mode.
Stills will be using the mechanical SR but there's still potentially enough hunting that a wobble will blur your photo if the reason you're on a tripod is to use a slower shutter speed.
01-20-2014, 01:17 AM   #8
adwb's Avatar
I have tested this a few times and with normal shutter speed can never see the difference. However with long exposures , a second or more, I suspect this might be what they are worrying about.
camera, dslr, image, k-5, k-5 ii, k-5 iis, k5, pentax, pentax k-5, photos, stabilization, stabilization vs. tripod, tripod
Why turn off shake with a tripod? Michael Piziak Troubleshooting and Beginner Help 46 12-30-2013 05:21 PM
K01 - main switch turn off camera in on position when pushed clockwise Foma2 Pentax K-01 5 01-23-2013 03:06 AM
When do you turn SR off? top-quark Pentax DSLR Discussion 69 12-13-2012 08:58 AM
When I did image stabilization wrong with a Zeiss Distagon 35/2 Chazz5 Pentax K-5 4 06-24-2012 11:55 AM
K100D Super makes noise when I turn it on jct us101 Pentax DSLR Discussion 4 03-14-2009 12:46 PM
All times are GMT -7. The time now is 05:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
