01-23-2014, 02:59 PM   #1
Can't view my images/playback doesn't work?
Hello, hoping someone can help me.
Bought a new K5 II a month ago and can't view images by pressing the playback button. \Spent time reading the instructions too in case was a weird set up procedure to do that but there doesn't seem to be...
Is there something wrong with it??? Or am I missing something simple?
Thanks
01-23-2014, 03:04 PM   #2
What, if anything, happens when you press the playback button?
As far as I know there is nothing particular that needs to be done to view images. Just press the playback button, and of course the camera has to be switched on.
01-23-2014, 03:09 PM   #3
jatrax's Avatar
Did it ever work? Might be a bad button.....
01-23-2014, 03:28 PM   #4
Nothing happens at all and nothing ever has happened? I can go into menu and watch a slide =show fine and after a photo the screen displays that picture but the playback one does nothing.... So you think a trip back to the shop is in need? Thanks for your quick responses!
01-23-2014, 04:45 PM   #5
jatrax's Avatar
What happens if you press the play back button and then press the info button? What should happen is that 'info' will cycle through the different play back displays. If instead you go to the regular 'info' screen with all the settings to be changed then I suspect the play back button is not working.
If that is the case try pressing and wiggling it a few times or pressing it repeatedly a few times. This has been reported to loosen up buttons in the past. If none of that works, sadly I think it needs to go back to the dealer or in for service.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, playback images view, view, view my images/playback
My K20D doesn't won't focus Slowpoke Rodriguez Troubleshooting and Beginner Help 5 01-06-2013 08:04 PM
My K5 shutter doesn't work with K mount M 50mm 1.7 MikeD Pentax SLR Lens Discussion 13 12-13-2012 01:24 PM
can't view video files on my laptop Mymon88 Pentax K-r 4 11-17-2012 11:31 AM
I don't understand why stop down metering doesn't work well at higher f stops. geekette Pentax DSLR Discussion 51 06-08-2011 10:39 PM
Silkypix doesn't work with my Mac! waxsage Digital Processing, Software, and Printing 6 01-19-2011 10:57 AM
All times are GMT -7. The time now is 03:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
