02-20-2014, 12:48 AM   #16
Racer X 69's Avatar
I got the Pentax grip for my K5. Like the one for the K10 the OEM piece is well made. My thoughts are why chimp out on this sort of thing, it isn't that much more up front, and in the long run and you get a much better quality component.
Things I have noticed that are different from the K10 to the K5 grip are the K5 grip has a much wider base front to back, so the camera should be more stable with a longer lens mounted, and the K5 grip does have a place for the Remote F SD card, but I don't see a place for the SD card Remote F like the K10 grip has.
The added tray for AA batteries is a nice touch, but the original batteries last so long that I doubt I will ever use it.
{Edit: I looked again this morning and the K5 grip has a place for the memory card, not the remote as I had said last evening.}
02-20-2014, 08:42 AM - 1 Like   #17
Canada_Rockies's Avatar
That's a bummer. I quite like having the remote in there. I suppose somebody thought the Remote F is so small you can put it anywhere, but the problem is that it IS so small you can put it anywhere and never find it again. (My middle initial is "K" - for Klutz)
02-20-2014, 09:05 AM   #18
Racer X 69's Avatar
QuoteOriginally posted by Canada_Rockies Quote
I'm with ya all the way.
I even toyed with the idea of using some epoxy and sticking a lanyard to the remote. But then it would not fit in the storage slot in the grip on the K10.
*sigh!*
battery, battery door, camera, door, dslr, k-5, k-5 ii, k-5 iis, k5, latch, pentax k-5, plastic
K200d Battery Door, No Power stand alone, But works with Battery grip pento57mm Troubleshooting and Beginner Help 10 08-18-2013 11:24 AM
Pentax Battery Grip BG-4 battery door voyager13 Troubleshooting and Beginner Help 4 07-13-2013 05:06 PM
Sunpak 422D battery door corrosion bass3587 Flashes, Lighting, and Studio 15 03-14-2013 07:29 AM
battery contacts melted into latch gregglewa Troubleshooting and Beginner Help 4 10-16-2011 02:52 PM
k2 battery door arkansas72762 Pentax Film SLR Discussion 3 01-10-2009 11:50 PM
All times are GMT -7. The time now is 05:10 PM. | See also: NikonForums.com, part of our network of photo forums!
