Hi I wonder if any one can clear this up for me?
the battery door and turn latch plate on the K5 body appears to be made of metal rather than plastic.
is that the case with the genuine Pentax battery battery grip?
I have a couple of 3rd party ones which have served well enough , not water proof I know, but the one fault is the little latch tag is made of plastic and eventually breaks. you can if you don't use the AA holder swap the bits around so you get more life of it but I was wondering if the genuine article is more robust?
I have to say that after 2 years of hard work this is the only problem I have had with these cheap ones.
