02-16-2014, 09:27 PM   #1
Which SD card for K5IIs?
Hello, can I get some recommendations for a good, fast SD card for the K5IIs?
I know I will need a class 10 card but I notice with the Sandisk cards, once the speed goes above 30MB/s they become a UHS-1 card also.
Will this UHS-1 cause a problem in a K5IIs?
Can the K5IIs make use of cards with speeds over 30MB/s?
Price is not a concern for the cards listed below.
30MB/s class 10
SanDisk Ultra SDHC and SDXC UHS-I Memory Cards
40MB/s class 10 UHS-1
SanDisk Ultra PLUS SDXC and SDHC UHS-I Memory Cards
45MB/s class 10 UHS-1
SanDisk Extreme SDHC and SDXC UHS-I card
80MB/s class 10 UHS-1
SanDisk Extreme PLUS SDHC and SDXC UHS-I card
95MB/s class 10 UHS-1
SanDisk Extreme Pro SDHC and SDXC UHS-I Memory Cards by SanDisk
Thank you.
02-16-2014, 09:31 PM - 1 Like   #2
QuoteOriginally posted by Dieseler Quote
Will this UHS-1 cause a problem in a K5IIs? Can the K5IIs make use of cards with speeds over 30MB/s?
No to both. This is the card I'd recommend, as it's just above the maximum write speed of 30 mb/s, so you'll get the best possible performance:
SanDisk 16GB SDHC Extreme Class 10 UHS-1 Memory SDSDRX3-016G-A21
02-17-2014, 12:02 AM   #3
Wired's Avatar
I pretty much buy Extreme Pros' for everything now, even if its faster than the camera. My idea is that if the card lasts that long I may still be using it when the faster camera comes out that can use the speed.
02-17-2014, 09:01 AM   #4
Thank you both for your help, it is good to know that UHS-1 does not cause any problems as most cards seem to have that feature now.
02-20-2014, 12:51 AM - 1 Like   #5
Man With A Camera
Racer X 69's Avatar
I agree with Adam. I have a 32gb card in my K10 and it is working great so far, but it is so big that I get lost browsing for files in it. The first time I went in there I got lost and didn't come out for three days.
02-21-2014, 12:29 AM   #6
Hello! I 've brought a Toshiba Exceria type 2 SD card for my K30,It is great! Of course it is a UHS-1 card. Read 95M/s,Write 60M/s.So it is the same class as SanDisk Extreme PLUS SDHC and SDXC UHS-I card,However,the Toshiba Exceria Tpye 2 is quite cheap than Sandisk!
Toshiba also have a another type SD card, Exceria type 1 ,Read 96M/s,write 90M/s.
It is no problem insert a UHS-1 card to K5.
My test is above.(intel dualcore CPU XP)
camera, card, cards, class, dslr, k-5, k-5 ii, k-5 iis, k5, memory, pentax k-5, sandisk, sdhc, uhs-1
Which SD card for K3? WA-surfer Pentax K-3 39 02-29-2016 05:33 PM
Which SD card to use for hi-speed burst shooting with K-30? GixxerMKD Pentax K-30 & K-50 11 02-24-2014 12:27 PM
Which SD card type is best used for the Q? kyuuan Pentax Q 27 11-08-2012 12:33 AM
Which SD card? Tatume Troubleshooting and Beginner Help 4 05-09-2012 03:25 PM
Question: Which SD Card for casual video? monochrome Pentax K-01 29 03-28-2012 07:39 AM
All times are GMT -7. The time now is 09:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
