03-01-2014, 01:02 PM   #1
SteveTheOldMan's Avatar
K-5ii issue...is it serious?
I swear this is a true story.
I was fortunate enough to purchase a K-3 about a month ago. Very good deal. I was actually taking photos of my K-5ii in order to sell it. (Wonderful camera, but I do prefer the '3'.) As I powered up the camera up one last time, a quick but very noticeable vibration occurs. Never, ever did that happen before. The camera has less than 7500 shutter actuations; I've had it for just over a year.
The camera still works fine, but I need to reevaluate how much to sell this camera for (if at all) if this camera has a serious defect. Any ideas or suggestions about where to look for more info?
Thanks very much.
03-01-2014, 01:07 PM - 1 Like   #2
It's the dust removal. It uses the sensor shift shake reduction to wiggle its bits all around & make the dust fall off the sensor. Yay!
03-01-2014, 01:12 PM   #3
QuoteOriginally posted by dansamy Quote
Maybe, but jeez, it's never been this loud...you gave me a thought. I 'reset' all settings. I've got to see if I turned something on/off then.
Thank you!
03-01-2014, 01:16 PM   #4
Yup. I think it's on by default. You may have had it off. Resetting the camera turned it back on.
03-01-2014, 02:48 PM   #5
I turned it the dust removal 'off' in the settings...still sounds the same. I did run a 'dust removal' cycle manually. Quiet as a mouse.
03-01-2014, 02:56 PM   #6
Yo!
I am a K-5 II owner stop putting things in my head.
Its something similar to a doctor advising a test - Chances are I will find a problem. :P
If it is vibrating very well, attach the egg beater to make a great pudding and enjoy your K-3.
Cheers!
03-01-2014, 03:08 PM - 1 Like   #7
QuoteOriginally posted by Deedee Quote
Yo!
Cheers!
I LOVE that!!! If I were you, I wouldn't worry about it. My problem is that I was going to sell the k-5ii to partially fund the k-3 that I already purchased. (Yes, that is backwards.) I kept both for an event I was doing, than the plan was to sell the '5'. Heck, I'd love to keep the k-5ii as a backup and call it a day! But that's really wasn't the plan...I had plans for that money...like bills... ;-)
03-01-2014, 03:21 PM - 1 Like   #8
QuoteOriginally posted by SteveTheOldMan Quote
Thank you!
Was it sitting on a table when you turned it on to take a photo of it? That very well might make it audible when it wouldn't be if held in your hand.
03-01-2014, 03:33 PM   #9
QuoteOriginally posted by IchabodCrane Quote
It was actually in my hands. It's just weird...dansamy's response makes so much sense. After the startup, it works fine...focusing is smooth, no problems...Maybe I should take it out for a day; it hadn't been used in almost a month. But I turned 'dust removal' back off and the vibration remained.
Thanks!
03-01-2014, 07:55 PM - 1 Like   #10
Class A's Avatar
Sorry, but dansamy's response makes no sense at all.
The K-5 (II) does not use the shake reduction mechanics to clean the sensor. It uses an additional ultra-sonic system. The latter is almost inaudible and does not vibrate at all (in a way that you can feel it).
Did you have a lens attached?
The only reason for a healthy vibration I can think of is that you somehow managed to put in a very high focal length (e.g., 600mm) into the focal length dialogue that pops up in the beginning when no modern lens can be detected. If the camera tries to stabilise such a long lens, it can visibly and audibly start to vibrate.
03-01-2014, 08:03 PM   #11
The k-5ii is still new to me. My K-x wiggles about like an excited puppy! My apologies for the wild goose chase.
03-02-2014, 05:20 AM   #12
Thanks for the help. Actually, no, I didn't have a lens attached...the dialogue was set to 85mm. Even after I attached a 60-250, no change.
Just for fun, I played with the dialogue you spoke about above, setting the lens first at the lowest value (8mm), then the highest (800mm, I think.) No change. It seems like the vibration happens before the dialogue is displayed, for what that's worth.
---------- Post added 03-02-2014 at 05:26 AM ----------
Any thoughts on the subject are *greatly* appreciated...they're more than I have right now. Since the issue seemed to happen AFTER I reset the settings, something I changed seemed to be a logical suspect. The problem is, I believe I only changed 2 Custom settings (21. "Flash in wireless mode" and 27. "Using Aperture Ring".) Even if I missed something, I can't see any other setting that seems to be a logical suspect.
03-02-2014, 07:05 AM - 1 Like   #13
Class A's Avatar
Of course there is the calibration phase for the aperture lever mechanism. It causes a short buzz and perhaps a tiny bit of vibration.
However, as you said the vibration you are observing is different to what you experienced before, it seems that it is not the aperture lever mechanism being calibrated that causes it.
Currently, I have no other ideas what the cause may be.
03-06-2014, 09:50 AM   #14
That's exactly what it is...only louder and more pronounced than before. Unless the k-3 is that much quieter than the k-5ii, which I don't believe to be the case.
camera, change, dslr, k-5, k-5 ii, k-5 iis, k-5ii, k5, length, lens, mechanical, pentax k-5, settings, suspect, vibration
K-5II & AK-TTL, (K-5II stabilization error) FECOmp Troubleshooting and Beginner Help 7 02-08-2014 09:23 AM
What is K-5II shutter resource and how much cost to change it ? Vejas Pentax K-5 2 01-10-2014 03:05 PM
Is the K-5II getting discounted? GabrielFFontes Pentax K-5 8 11-09-2013 05:49 AM
K-5II focusing screen or sensor issue toukan Troubleshooting and Beginner Help 7 12-09-2012 12:14 AM
Front/Back Focus issue - Is it the camera's problem or is it the lens? vtqanh Pentax DSLR Discussion 10 09-26-2012 04:58 AM
All times are GMT -7. The time now is 05:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
