Originally posted by micromacro Is it really improve the performance, should I bother to update?
It's usually a good idea to keep the firmware up to date, I think. There have been a lot of useful performance and other changes from v1.0 to v1.07, by the look of it.
And if you plan on using the HD PENTAX-DA AF REAR CONVERTER 1.4, the DA 560mm lens, or any of the new Pentax flashes too, I'd say updating your firmware would be a required step.
K-5II firmware changes:
Changes to V1.07
Correspond to HD PENTAX-DA AF REAR CONVERTER 1.4X AW.
Improved stability for general performance
Changes to V1.06
Corrected – Unstable performance may rarely occur in firmware version 1.05.
Changes to V1.05
Correspond to the AF assist light function by white LED light for auto flash unit [AF360FGZII] and [AF540FGZII].
Optimized contrast AF when using HD PENTAX-DA Limited series lenses
Changes to V1.04
Corrected – Switch operation may not rarely work during displaying Status screen in firmware version 1.03.
Improved stability for general performance.
Changes to V1.03
Improved the accuracy of exposure when using AA batteries.
Changes to V1.02
Optimized contrast AF when using [HD PENTAX-DA 560mmF5.6ED AW] lens.
Changes to V1.01
Enabled contrast adjustment on Monitor.
(Added [contrast ]on [LCD setting ]menu)
