03-11-2014, 10:25 PM   #1
Need advice for SOOC settings
Looking for advice from others who (almost always) shoot JPGs in preference to RAW. Not looking for a lecture on RAW advantages. Here, I'm looking for tips from others who have found that it's just faster and easier to get a reasonably good JPG Straight Out Of the Camera (SOOC) than to spend a lot of time post-processing in Lightroom, etc -- to end up with roughly the same thing. Looking for advice and tips that might translate into the K-5 USER modes.
If you have any USER 1-5 settings that are helpful, please let me know! I'm starting with USER 1 on TAv, HDR Auto, D-Range highlights and shadows On. For indoor pix, like below (both handheld).
Image 1 is a JPG (spot-exposed for the bright menu board) that I then saved as a RAW file during Playback. On screen, the RAW file looks just like the JPG, and would need extra work in Lightroom to bring up the shadow areas.
Image 2 is SOOC, from my new USER 1 settings. Spot-exposed same as above... with the JPG the result of the K-5 IIs' in-camera processing. Will use this for ambient-light interiors, where the processing time inbetween shots doesn't matter.
PENTAX K-5 II s  Photo
03-11-2014, 11:39 PM   #2
QuoteOriginally posted by jon404 Quote
You are not looking at the RAW file *on screen* Jon, you are looking at the JPG preview image (with applied camera settings). RAW is not a picture you can see, it's data you process.
I think I've mentioned this somewhere else to you before
Think of it like a box of cake mix. It has a preview of the baked cake printed on the box, but inside are just the RAW ingredients.
03-12-2014, 12:14 AM   #3
Sure, I know that. Am looking here to see if others are trying to avoid the whole RAW>Lightroom slowdown. Not in some cases of course... but for most pictures where you just don't need time-consuming post-processing.
It also occurred to me that a USER-mode-tailored JPG, processed in-camera like #2 above, could be the best starting place for any simple, very fast post-editing -- like with the Xara Designer Pro or Xara Photo & Graphic Designer software that both Steve (above) and I use.
This isn't a RAW vs JPG discussion... that doesn't make sense. Am just thinking that RAW is time-wasting overkill for 90% to 95% of the pictures we take... but truly necessary for the remaining 5% to 10%.
03-12-2014, 12:45 AM   #4
Sandy Hancock's Avatar
Get real. This *is* a RAW vs JPEG discussion.
Anyway, for me at least, post-processing isn't time-wasting overkill; it's FUN! To some extent it depends on how much time you have to get everything exactly right at capture, and how much you care about the output.
03-12-2014, 01:17 AM   #5
Sandy -- I don't think of it as one vs. the other. For instance, i would definitely want RAW for any B/W images, to be able to output a JPG with as full a range of tones as possible.
Maybe it has to do with our personal styles. I like to take a lot of pictures, and have found dealing with them in Lightroom too time-consuming. Although, as Steve has pointed out to me in the past, it doesn't help that I'm using a small Acer netbook for all this!
But again, it's not a RAW vs. JPG thing. My camera easily lets me use RAW/Fx One Push File Format, to take a RAW image at any time... or to save all images as RAW + JPG. At my end, I'm just trying to simplify things as much as possible -- and I keep coming back to JPGs with an occasional RAW image for difficult scenes.
03-12-2014, 01:41 AM   #6
What do mean by a lot of pictures? At an all-day music festival I may take 4000 images. All RAW. The website which buys my access to these gigs expects me to have a gallery of 300+ jpegs up within 24 hours. I could save some time shooting jpeg, but then my output wouldn't look *better* than the pros with their FF CaNikons.
03-12-2014, 01:45 AM   #7
Here's a special JPEG setting I use sometimes when I want to tackle a high-contrast scene such as a dark interior lit by a
sunny window, and I can't use HDR because of motion in the scene:
highlight protection on, shadow protection on max
high/low key +4
contrast +3
saturation -1
EC -2 (adjust to taste)
centerweigted or matrix metering
The setting combo is a form of extereme shadow lift.
Alternatively, you can use EC +2, spot metering and meter the bright part of the scene.
Regards,
--Anders.
03-12-2014, 02:33 AM   #8
QuoteOriginally posted by asp1880 Quote
high/low key +4
contrast +3
saturation -1
Regards,
--Anders.
You have time to think about this, and jiggle through the menu each time the conditions change? When the pressure is on I would rather concentrate on capturing the moment, then spend the time in post when the pressure is off.
03-12-2014, 02:59 AM - 1 Like   #9
Exactly, fiddle with the camera picture style settings and get a lossy JPG, or fiddle in Lightroom and get what you really want and save the untouched RAW for re-development later when the fancy takes you.
Remember, Jon - you can rattle off a dozen shots of the sunset with the surfliner training by, open all 12 in Lightroom - develop ONE then sync the other 11.
Fast, easy and you haven't lost anything. It's a win-win.
03-12-2014, 03:09 AM   #10
@Anders -- thanks! Up to now, have dealt with that scene by exposing for the window, then adding flash to brighten the room. Takes time. Will try your settings tomorrow, should be a real help -- particularly by letting us avoid HDR because of the motion problem you mentioned.
@Sandy -- I'm retired, not doing this for a living -- so no requirement from others for RAW, like your concert pix. 4000 RAW images in one day -- that's a lot indeed. With a filesize load like that, I'd write my Congressman to get some storage space on one of those NSA servers that my tax money is paying for!
@Steve -- I think for Christmas I'll get a faster computer, which would go a long way to help with Lightroom. And, by then, my Congressman will have freed up 100 terabytes on an NSA server for all the RAW files I'll be generating...
03-12-2014, 03:35 AM   #11
What I may not have spelled out is that my live music work is pro bono. I get free tickets and fantastic access, but no payment. I am a strictly amateur photographer with a (fortunately) very well paid day job.
There is no way tonedeaf.com.au could afford me at my usual hourly rate. I spend the time I do on post processing because it makes a material difference to the quality of my output. If you don't care, don't bother.
03-12-2014, 05:27 AM   #12
So would I. And I do. I shoot RAW when I think I can't finish the shot well enough in camera for my personal standards because of time pressure, importance or difficult light. But often I find there is plenty of time to analyse (contrast, colours, white balance etc) and set up accordingly.
Besides, I have those JPEG settings in a USER mode so it's not all that fiddly.
I also sometimes redevelop the latest, buffered shot with variations in contrast or colour settings. If there is time.
Regards,
--Anders.
03-12-2014, 06:22 AM   #13
Jon, if you seek a user preset to deal with especially challenging light situations to get a good JPEG then I think you won't find it. Every difficult scene is unique so there can't be a single preset that's going to produce what you likely want.
OTOH, there are some non-default settings that I think are better than the Pentax default for JPEGs. There have been many threads on the subject and no consensus but, lately, I've tended toward Portrait with a little reduced saturation and boosted sharpness. Add a couple points to Amber on the WB. Give it a try and tell us what you see.
advice, advice for sooc, camera, dslr, image, jpg, k-5, k-5 ii, k-5 iis, k5, pentax k-5, settings, sooc, time, user
Advice for new K5 owner? (settings, etc) jmbower Pentax K-5 8 12-06-2013 06:51 AM
Need advice on a trumpet for son Docrwm General Talk 11 05-28-2013 01:33 PM
Need Advice for Group Shot KimM Photographic Technique 13 05-16-2012 04:51 PM
Need advice for wildlife lens coreyhkh Pentax SLR Lens Discussion 33 04-23-2012 10:54 AM
Advice for settings. Stratman Digital Processing, Software, and Printing 3 05-19-2007 11:37 PM
All times are GMT -7. The time now is 01:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
