03-29-2014, 02:56 PM   #1
Filming stars
Tried to film stars (with kIIs) and got dark imges. While setting foto mode (Av, M, etc), the live view shows overexposed stars but switching to movie, live view and the record is blank even if I set +2 exposure compensation. Am I missing something?
Thanks.
03-29-2014, 03:43 PM   #2
TER-OR's Avatar
The videos you often see of stars are actually time lapses of separate images. Usually you can do a few seconds per shot, and then use a software program to build them all into one movie.
03-29-2014, 03:48 PM   #3
No stills, no timelapse, just movie because I want 30fps.
03-29-2014, 04:00 PM   #4
QuoteOriginally posted by valy Quote
Well, there's your problem: Each frame will only have a 1/30s exposure time - try that with stills, even at very high ISO, and you will see that only the very brightest stars will be captured.
03-29-2014, 04:05 PM   #5
Dr_who's Avatar
Just take more images and you can have 30fps
03-29-2014, 04:09 PM   #6
I want real 30fps, or 25, meaning I want to aquire 25-30 frames per second.
So there is no way to set iso 51.200? How live view does to get proper images of faint objects and the movie mode don't?
03-29-2014, 06:35 PM   #7
You want to record 30fps and playback 30 fps? The stars are not very interesting in real time video. Most star videos are done as a timelapse.
Possible starting settings with the 18-55 kit lens: 18mm, manual mode, f4.0, 30 second shutter, ISO 1600, 2 megapixel JPG, set the intervalometer to take a photo every 32 seconds. Let that run for ~300 shots.
Then use your existing movie software or Startrails application to merge the JPGs into an AVI. 300 shots played at 30 fps will yield 10 seconds of video.
Startrails also has the option to stack all the JPGs into one image, like
03-30-2014, 05:43 AM   #8
I want to record 30fps, don't care the playback, just to record some signal.
03-30-2014, 11:15 PM   #9
valy.
Divide 1 second by 30 and your answer is 0.0333333333 which = 1/30 as mentioned by Stone G.
You're really not going to get enough light to register on the sensor in such a short time even with the fastest lens available.
Super high ISO will make more noise than stars
03-30-2014, 11:48 PM   #10
@Valy, can you explain why you want a 30fps capture of stars? The night sky usually doesn't change so quickly to make an interesting real-time video. Are you trying for an eclipse or occultation?
03-31-2014, 02:07 AM   #11
Actually I want to film the seeing variations (air turbulences) at high fps (25-30 is max for k5), I need a bigger sensor (more surface) than my astro CCD camera which has only 640x480px. Examining the movie I've noticed that is pure black, no noise, perhaps the camera didn't raise the iso. I don't mind having noise since there is also usefull signal into the movie.
With my astrocamera I've managed to have a lot of signal at 30fps (0.03 ms exposure) and gain ~800 (from 0-1000 range) and it has almost the same pixel size and sensibility as k5 sensor, this on faiter star. So I expect the k5 is capable to get some white pixel at least on Jupiter which is brigter. I feel there is a missing setting but there is no actual settings to do, all is automatic. I'll try the user mode trick to force it to raise iso and set exporure 1/30s.
On the other hand, on photo mode - live view there is my star visible, so the sensor is capable to catch the light very well, but not in movie mode.
03-31-2014, 04:22 AM   #12
If you want to film the seeing variations, the Moon is an excellent target. You can also make movies with your DSLR with Jupiter as a target. However, you should realize that even HD movies are quite highly compressed, so you will never utilize the full, spatial resolution of your sensor in movie making. I suggest you take a look at the thread in the Astrophotography Group here:
https://www.pentaxforums.com/forums/groups/135-astrophotography/1486-dslr-video-astrophotography.html
03-31-2014, 04:51 AM   #13
Actually I want such of this: http://arxiv.org/pdf/astro-ph/0111022.pdf
A mask infront of the telescope, image a little bit defocused and take a movie.
03-31-2014, 05:03 PM   #14
Okay, now the 30 fps makes sense. It's for scientific purposes to measure atmospheric seeing rather than capturing a nice-looking image.
The mask cuts down the amount of light (by reducing the aperture) but it should still work depending on the size of the telescope. I built a homemade Hartmann mask for focusing (with 3 triangular holes) and I got enough light through it with an 8" Schmidt-Cassegrain. A similar design on a 3.5" refractor was too dark for my K-5.
04-03-2014, 01:27 PM   #15
Science is more interesting than some nice-looking images
Finally I've decided to use the astrocamera for this, is more flexible/controlable.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, live, pentax k-5, stars, view
K-7 JPEG Quality four stars vs. three stars PentaxRev Pentax DSLR Discussion 14 04-02-2016 07:49 AM
AE-L locking during filming? glealisla Pentax K-01 17 08-29-2013 07:38 PM
Filming Na Horuk Pentax K-01 6 07-01-2013 02:46 PM
Help with the theory behind filming. Meme Video Recording and Processing 12 11-05-2012 05:27 AM
Best Pentax camera for filming? Vininski Video Recording and Processing 11 06-10-2012 07:24 AM
All times are GMT -7. The time now is 09:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
