03-30-2014, 11:35 AM   #1
low iso problem k5ii2
Hi
My k5 ii2 will not go under 160 iso. The expanded iso is activatet. Any proposals on whats wrong?
03-30-2014, 11:40 AM   #2
fgaudet's Avatar
Disable highlight and shadow correction (under D-Range Setting)
03-30-2014, 04:08 PM   #3
Na Horuk's Avatar
Yes, keep the ISO expanded, but disable highlight correction. You can read up on what highlight correction does.
Basically, it prevents you from "choosing" the lowest ISO, but the camera still uses it. It simply always shoots one ISO lower than the chosen one, then digitally brightens the photo by one stop, while making sure the highlights don't clip (highlight clipping is when highlights turn white, usually happens with the sky near the sun). So, you don't have to disable highlight correction to use ISO 80, you just need to disable it to be able to "select" the number 80.
03-30-2014, 11:38 PM   #4
hi
thank you very much for the quick answer. It solved the problem
camera, dslr, iso, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Super low ISO?? 45 Mike Pentax DSLR Discussion 30 02-25-2014 04:54 AM
Why no low ISO settings? GibbyTheMole Pentax DSLR Discussion 13 06-29-2013 03:45 AM
K5iis High ISO/Low Light questions candgpics Pentax DSLR Discussion 6 05-24-2013 08:32 PM
ISO ranges and low iso, techies please look. Gooshin Photographic Technique 7 09-09-2009 07:37 PM
Night photography with K10D - High ISO short exposure VS Low ISO long exposure pw-pix Pentax DSLR Discussion 10 02-03-2008 01:37 AM
All times are GMT -7. The time now is 07:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
