04-01-2014, 11:23 AM   #1
Pentax K-5 II Using RAW +
I was caught up in the debate over RAW vs. JPEG and decided to shoot RAW+ for a while. After loading the double photos into my computer, I noticed that, other than the difference in the file sizes, the appearance of the RAW vs. the JPEG images were pretty much identical. I am using a MacBook Pro with a Retina screen.
This leads me to the question of precedence. Is the JPEG image made FROM the RAW image? Or does the JPEG image reflect the camera settings that would be invoked if you were shooting JPEG only? That is, if I choose Bright or Vivid images with bumped up saturation, will the JPEGs be made with these parameters taken into account. Appearance-wise it looks like the first case is true.
What is the precedence and picture taking protocol for RAW+?
Thanks!
Barry Scholles
04-01-2014, 11:34 AM   #2
Parallax's Avatar
QuoteOriginally posted by StrasburgBarry Quote
Yes. It will also apply those settings to the embedded jpeg in the raw file. When comparing them they look the same, probably, because the viewer you are using is not processing the raw file but rather displaying the embedded jpg.
04-01-2014, 11:59 AM   #3
I initially used Picasa with my old PC. Now viewing in iPhoto with my Mac. I do understand there's an imbedded JPEG inside the RAW image. However, the JPEG image right next to the RAW image looks like it has had zero camera controls applied to it. This is not the case when I shoot JPEG only, which is what I've gone back to.
04-01-2014, 02:11 PM   #4
The JPEG should normally also have the camera controls applied to it. Are you sure about this? I don't think I ever paid close enough attention to know for sure, but I'd always believed the JPEGs were the same either way.
04-01-2014, 02:27 PM   #5
FWIW I shoot RAW+ on both my K-5ii and my wife's K-50 - In my case the RAW files before processing look much worse than the JPEGs that come from the camera, sometimes I will look at the JPEG when working with the RAW file to get started in the right direction...
04-01-2014, 02:48 PM   #6
Do you have iPhoto set to separately import each file? If yes, the library viewer will display two images for each shot... the RAW and JPEG side by side.
04-01-2014, 04:53 PM   #7
Yes, there are two images, side by side and one is a RAW file, the other a JPEG.
I think the point of my question is being misunderstood. What I'm talking about here is what appears to be two different types of JPEG images. When I shoot RAW+ both the RAW and and the JPEG images resemble each other. I would expect the RAW image to look unprocessed by the camera. But the JPEG ALSO looks like the camera hasn't done anything with it.
When I shoot in JPEG only, I can see the camera adding the extra saturation I requested or shooting in Bright or Vivid.
But I do not see these camera modifications to the JPEG images when I shoot in RAW+.
That is the point. There appears to be two different types of JPEGs here.
04-01-2014, 05:37 PM   #8
Definitely not how the K-7/K-01/Q and MX-1 work.
Camera setting processing is done for JPEG and embeded JPEG. RAW has zero processing.
Easiest way to check is to set custom image to MONOCHROME then shoot a RAW, RAW+ and a JPEG.
Both JPEG images will be identical Monochrome versions and the initial view of a RAW in most apps will be the embeded JPEG, so will also be Monochrome, but load the actual RAW data and you will get a full colour photo.
camera, dslr, image, images, jpeg, k-5, k-5 ii, k-5 iis, k5, pentax k-5, pentax k-5 ii, raw+ precedence, vs
New Pentax K-5, K-5 II & K-5 IIs Adobe Camera Profiles PentaxGuyUK Post-Processing Articles 7 12-04-2014 05:02 AM
New Firmware for K-500, K-50, K-5 II, K-5 IIs, K-5, K-30, K-01, K-r, and 645D is out Adam Pentax News and Rumors 60 09-16-2013 05:46 AM
K-5 ii RAW issue anthonyarm Troubleshooting and Beginner Help 8 07-14-2013 05:21 PM
Flickr not differentiating between K-5, K-5 II, and K-5 II s Corby Pentax K-5 5 04-27-2013 04:05 PM
K-5 ii vs K-5 iis comparison with higher sharpness in K-5 ii kataria0 Pentax K-5 62 12-22-2012 10:12 PM
All times are GMT -7. The time now is 06:22 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
