04-06-2014, 09:23 PM   #1
Is there a quick way to switch from RAW to HDR and back?
This weekend I used the HDR setting quite a bit and I got really tired of first having to switch to JPEG, then to HDR and the reverse sequence when switching back. With my old Panasonic you could just switch to HDR and the camera would automatically switch to JPEG which was much faster and more convenient.
Is there a way to switch the K-5ii faster to HDR ideally with one menu or button press?
04-06-2014, 09:32 PM   #2
Set up a custom user mode for HDR.
04-06-2014, 10:00 PM   #3
I also shoot raw with my K-5IIs and find an occasional need for HDR. I just switch to a 3-shot bracketed sequence and do post-processing in Lightroom where LR sends the three shots over to Photoshop for an HDR combo which ends up back in LR as a tiff (if I remember correctly). I try to stay in RAW mode all the time.
04-06-2014, 11:50 PM   #4
adwb's Avatar
Set a custom mode
04-07-2014, 01:01 AM   #5
fs999's Avatar
I have assigned exposure bracketing to the RAW/Fx button, so it is easy to switch...
04-07-2014, 09:01 AM   #6
QuoteOriginally posted by adwb Quote
Set a custom mode
That might be an option although as far as I know the custom mode will store all other settings which might not always be desirable.
Or is there a way to have a custom mode that sets only one or two parameters and leaves everything else alone?
04-20-2014, 09:42 PM   #7
QuoteOriginally posted by fs999 Quote
I've done that also but maybe I'm expecting something else, as well.
When I press the Raw/fx button, indeed, the camera is set for the bracketing I've set up in the menu system (5 exposures -2,-1,0,+1,+2 in my case). So far so good. But when I want to turn this off and go back to single picture mode, it appears I must press "menu" and then left-left-left-left-OK (or something like that in order to turn auto-bracketing off. Have I not programmed something properly? The Green button doesn't seem to cancel this mode.
I think I've RTFM but a little help here would be appreciated. Thanks!
Barry
04-21-2014, 01:29 AM   #8
fs999's Avatar
QuoteOriginally posted by rumplestiltskin Quote
Barry
There is no way to turn it off with one button, but if you press Raw/fx again then right-right-Ok, it will do the trick
04-21-2014, 06:45 PM   #9
Yep; that'll do it. I saw another thread where someone assigned the auto-bracket feature to the User mode. I think another work-around is to set the camera to not remember the settings when powered off so a "power off / power on" would also work (but I hate doing that to electronic equipment).
Thanks!
camera, dslr, hdr, jpeg, k-5, k-5 ii, k-5 iis, k5, pentax k-5, switch
Is there a way to quickly force flash off/on from K30? akomlik Pentax K-30 & K-50 9 12-03-2013 06:03 PM
Is there a way to sync over 1/125? bcroslin Pentax Medium Format 8 10-24-2013 12:06 AM
Is there any way to adapt a rear PK mount to filter threads? GibbyTheMole Pentax SLR Lens Discussion 9 05-18-2012 04:33 PM
K-5 Is there a simple way of going from HDR back to RAW? allantois Pentax K-5 11 10-23-2010 05:42 PM
Is there a quick way to list out all particpated posts which have new posts? RiceHigh Site Suggestions and Help 10 05-27-2007 10:06 PM
All times are GMT -7. The time now is 10:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
