04-18-2014, 10:54 AM   #1
Use of Shadow Correction On Low
Hi,
I sort of doubt that I am going to use it, but am curious about the use of Shadow Correction on the Low or Medium setting if I am shooting JPEG and RAW. I presently use the Highlight Correction and I have found it valuable. I suppose with testing I would find out, but I am sort of curious about a second opinion. I suppose a Low setting might help in some situations, but I am not sure if the Medium or High settings would do too much. I now use TAV mode and naturally look for a good ISO after I have made my other settings, but I am curious as to if the Highlight Correction might help without taking away the value of the overall image. I really have done very well most of the time without the Shadow Correction, but as I mentioned I am just looking for some opinions, especially about the Low or Medium settings if you possibly have some. I am using a K-5 and a Sigma 150-500 lens.
Thank you.
04-18-2014, 11:18 AM - 1 Like   #2
I keep it set lower (on low, IIRC) with HL correction off. At least this is what I liked.
04-18-2014, 01:53 PM   #3
QuoteOriginally posted by DSims Quote
DSims,
If it is what you like, I suppose it seems to bring out some of the image features in an effective way using the Low setting. I may possibly test it for some samples sometime. I am curious if it would effect the ISO that registers when I am using TAV. If at all, I would probably use it (Shadow Correction) on the Low setting if I am using the Highlight Correction also. Otherwise, I could just test them all (Low, Medium, and High) if I want to find out how they actually effect images.
Thanks.
04-18-2014, 02:01 PM - 1 Like   #4
I suggest you use shadow correction according to the scene. The higher the contrast the more shadow correction.
Shadow correction brightens the dark parts of the scene.
The high/low key slider in the custom image settings brightens or darkens the midtones.
The contrast slider controls the steepness of the S-curve.
All three settings can be used in concert to control the final image.
Regards,
--Anders.
04-18-2014, 02:27 PM   #5
Anders,
Thanks for pointing out those different aspects. As I mentioned, I may test with the different levels of shadow correction and see what they do (learn them). I have not used the high/low key slider or contrast slider yet. As you said, the use of the tools effectively is according to the scene factors. I have been shooting birds and they sometimes move from one area to the next with quickly differing light, so I may try the Low setting of the Shadow Correction and the Highlight Correction (both on) simultaneously as a general test. If I need the slider controls, I may also try them.
Thanks,
Casey
04-18-2014, 03:29 PM - 1 Like   #6
QuoteOriginally posted by C_Jones Quote
DSims,
Thanks.
It was just my overall preference. I tested all possibilities and chose. I PP if I really care, but it works fine for those times when I don't need to (or it's impractical).
04-18-2014, 03:37 PM   #7
That sounds like what I will do is test for different situations if I need to. Thanks again for your help.
Casey
camera, correction, dslr, highlight, k-5, k-5 ii, k-5 iis, k5, medium, pentax k-5, settings, shadow, shadow correction
Shadow correction applied to raw files? outsider Pentax K-5 & K-5 II 21 10-18-2013 11:54 PM
Highlight/shadow correction features slip Pentax DSLR Discussion 5 03-06-2013 11:54 AM
Shadow and highlight correction Alberts Troubleshooting and Beginner Help 9 07-25-2012 08:04 AM
Highlight & Shadow Correction tblachowicz Pentax K-5 & K-5 II 3 01-02-2012 08:56 AM
K-7 Hightlight Correction & Shadow Correction & Raw Christopher M.W.T Pentax DSLR Discussion 6 06-10-2010 03:32 PM
All times are GMT -7. The time now is 03:36 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
