05-02-2014, 08:41 PM   #1
K-5 and PC flash issues
Hello Everyone,
I am having alot of trouble getting my K-5 to send a flash signal through the PC remote, without using the built in flash, or external flash mounted on the hotshoe at the same time. I would like to be able to not have to have frontal lighting. I just got a new lighting kit, and the issue seems to be in the K-5, not the flash kit. does anyone know what I am doing incorrectly?
Thank you,
05-02-2014, 09:12 PM   #2
Ole
Ole's Avatar
Are you using the X exposure mode setting?
That may not be absolutely required, but setting the camera to X will ensure that the shutter speed doesn't exceed the flash sync speed of 1/180s. One thing less to worry about.
05-02-2014, 10:02 PM   #3
Just tried that, no difference, I still need to have the built in flash or an external flash in the hotshoe.....
05-05-2014, 04:09 AM   #4
Timd's Avatar
I have used the PC connection directly connected to Elinchrom D-Lite with no problems. Can you give us the complete set up you are using?
05-05-2014, 10:47 PM   #5
For some reason It decided to work as planned today... Thank you guys!! I think my K-5 is moody or something
05-07-2014, 12:33 PM   #6
PC cables are notoriously temperamental.
Calumet used to sell a little tool for squeezing the PC conector to ensure good contact.
The other option is to always carry multiple spare cables
05-13-2014, 11:59 PM   #7
that is a good piece of info, it explains alot of issues I am having
05-15-2014, 05:46 PM   #8
Adorama stock
Westcott PC Cord Repair Tool
MFR: 8007 SKU: WEPCCRT
camera, dslr, flash, k-5, k-5 and pc, k-5 ii, k-5 iis, k5, kit, pc, pentax k-5
New Firmware for K-500, K-50, K-5 II, K-5 IIs, K-5, K-30, K-01, K-r, and 645D is out Adam Pentax News and Rumors 60 09-16-2013 05:46 AM
issues with K-01 built-in flash dstructor Pentax K-01 11 03-30-2013 11:52 AM
Pentax K-5's issues with external flash minkuei Pentax K-5 12 09-10-2012 09:14 AM
Stained sensor and other issues K-5 lesmore49 Pentax K-5 19 11-29-2011 04:27 AM
Test: K20D PC sync and older flash Matjazz Pentax DSLR Discussion 8 08-15-2009 02:00 AM
All times are GMT -7. The time now is 09:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
