Originally posted by GvilleRick I teach at a high school and last night was our annual Prom. It's always a challenge with low light, flashing lights, and lots of movement. In particular, we have a tradition of a "Senior Walk" where the seniors and their dates are announced and recognized. It moves pretty quickly and in the past my best option was to prefocus and then set the camera to manual and shoot the shots. I would have to refocus from time to time as they would drift to a different spot to stop and I would have several blurry shots.
Last night I took a few lenses including a Sigma 28-70 f/2.8 that has worked pretty well outside for me but I've not been real happy with it inside in just normal conditions. I also took my Sigma 18-50 f/2.8 and my Pentax FA50 f/1.4. The 28-70 ended up being my most reliable in catching focus pretty quickly despite conditions so I used it for the Senior Walk. Next to me was a photographer from the local newspaper using, I suspect, an older high end Nikon. She was frustrated throughout the Senior Walk trying to get focus locked before the next couple was announced. I kept my K5iiS on AF-S and was able to lock all 91 couples. There were a few that didn't lock until they were moving forward but the only shot I had to retake was one where apparently my flash and the news photog's flash went off at the same time resulting in a very overexposed image, You can see the results at
Prom 2014 Senior Walk Hi, I had a look at the party pictures. Here are some things I learned while taking photographs at salsa parties:
The flash is harsh in your portraits. Using an Stofen omnibounce makes it a bit softer and I just loaned an imitation Lightsphere from a friend and start experimenting with that. The point is creating a larger surface as the source of light. When I stand close to a white wall I turn my back to the wall, point the flashhead back to the wall and up at 45 degrees, this creates a large source of light. Have a look here for a lot of ideas:
http://neilvn.com/tangents/wedding-photography-adapting-photographic-light-lighting/ and google flash modifiers to get some ideas.
You have portraits with the dance floor as background and others with brick walls. The first type look much better. Even when the subjects are standing with their back against the wall I always ask them to turn around and position myself between them and the wall.
I think you balanced flash and ambient light well.
I avoid turning the camera vertical because I don't like the shadows the flash throws to the side of the subjects. Some photogs use brackets to bring the flash above the camera but I just shoot landscape and crop. 18 MP is more than enough to crop and still have plenty resolution for publishing on the web.
I liked your series, it gave a good impression of the party.
Karet
