06-14-2014, 02:18 PM   #1
Multi Segment v. Average Metering
I guess a newbie question?
So my k-5 will do 77 multi segment metering. Does that mean that each sensor exposes the corresponding pixels to what it determines is best exposure for those pixels? Or, does it simply average the exposure over all the segments and the camera shoots at that average? If it averages over all segments how is that any better, or different, from my old Pentax film cameras that averaged over the entire frame and exposed accordingly?
Thanks!
06-14-2014, 02:25 PM   #2
It averages all the segments (occasionally applying weights) and determines the optimal exposure for the whole image. Old pentax film cameras generally only provided spot metering, or the EV in the very center of the frame. In other words, if you had something very bright in the center of the viewfinder and went with the light meter's recommendation, the whole image would be under-exposure. This wouldn't be the case with modern matrix metering, though you occasionally still need to use exposure compensation to fine-tune the camera's suggestion.
06-14-2014, 02:37 PM   #3
OregonJim's Avatar
They had center-weighted metering, which gave priority to the center of the frame. Multi-segment metering is a little smarter, because the on-board computer can look up the metering pattern in a database of known 'scenes'. It knows that a bright upper third of the frame is the sky, for example, and weighs it accordingly to avoid underexposing the foreground. In most situations, multi-segment works fairly well.
06-14-2014, 09:34 PM   #4
Thanks folks!
camera, dslr, exposure, k-5, k-5 ii, k-5 iis, k5, metering, multi, pentax k-5, pixels, segment, segments
Linking AE to AF Point during Multi-Segment Metering i_trax Pentax DSLR Discussion 3 05-21-2012 05:28 AM
I got multi-segment metering on an M42 lens--how?! MobiusOne Pentax DSLR Discussion 15 11-29-2011 08:45 AM
Super-Takumar 135/2.5 M42: Multi-Segment Metering on K-x? RolloR Pentax DSLR Discussion 2 11-07-2010 04:48 AM
Sigma 30mm f/1.4 compatible with Pentax K-7 Multi-Segment Metering brosen Pentax DSLR Discussion 4 10-25-2009 10:29 PM
multi-segment metering and M lenses newarts Pentax DSLR Discussion 11 03-09-2009 01:45 PM
All times are GMT -7. The time now is 08:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
