08-12-2014, 11:31 PM   #31
This is how it looks like when I was using matrix metering, same thing...
05-28-2016, 02:22 PM   #32
Update Please !!!
QuoteOriginally posted by Apost. Quote
Update:
Sevice center called me today, they said they have not seen this type of behavior before, so they don't know what's wrong, but they will look into it.
Warranty expires in just three days so i guess i did the right thing.
Hi Apost.
Did you get this sorted out and if so what was the issue. I have a K5 which I'm having issues with the metering. I mainly use M Mode and if I dial in the correct exposure it will take a photo that is way overexposed. I can dial exposure in that show 3 stops under and it is still overexposed. I've had the camera serviced (cleaned) but still an issue. Not sure the guy really knew too much to be honest.
My initial thoughts is the aperture mechanism is sticking ?
05-29-2016, 02:20 AM - 1 Like   #33
If i remember correctly the camera was sent to the hq service center in France.
A month later i got it back along with a letter stating that the cameras metering function is within limits...
Eventually i turned the camera into a permanent ir camera, so the metering does not bother me as much.
Never discovered what was the problem.
Moved to Nikon since.
Your problem is different, try another lens.
Sticky aperture or smthng pops into my mind too.
auto, camera, defaults, dslr, exposure, firmware, focus, iso, k-5, k-5 ii, k-5 iis, k5, kx, lenses, light, live view, meter, pentax, pentax k-5, reset, spot, time, underexposes
K10D metering issues fishy Pentax DSLR Discussion 19 03-03-2012 03:20 PM
Metering issues with Pentax Jüri Pentax Film SLR Discussion 9 02-21-2012 05:46 PM
Metering issues with MF lenses PentHassyKon Pentax SLR Lens Discussion 36 05-01-2009 04:16 PM
Me Super - Metering Issues unixrevolution Pentax Film SLR Discussion 20 04-23-2009 06:50 AM
Metering issues? mchud Pentax DSLR Discussion 27 10-23-2008 04:19 PM
All times are GMT -7. The time now is 06:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
