Originally posted by carrrlangas you need to put the profile file in the lightrooms profiles folder. Then, in lightroom, in the cmaera calibration tab, you can select the profile.
http://members.lightroomqueen.com/Knowledgebase/Article/View/1373/205/lightr...ault-locations
"Your custom Camera Raw & Lens Profiles should be installed to the User folders…
Lightroom 5 no longer uses the shared ProgramData (Windows) / Application Support (Mac) folders for Camera or Lens Profiles. Instead, it stores the built-in profiles with its program files.
When you create camera or lens profiles, they must be stored in the user locations listed below. If you previously stored custom profiles in other locations, you’ll need to move them to these user folders, otherwise Lightroom won’t be able to find them.
Windows—C: \ Users \ [your username] \ AppData \ Roaming \ Adobe \ CameraRaw \ CameraProfiles \
Mac—Macintosh HD / Users / [your username] / Library / Application Support / Adobe / CameraRaw / CameraProfiles /
For the lens profiles, substitute the LensProfiles folder for the CameraProfiles folder.
The camera and lens profile file extensions are:
.dcpr—camera profile recipe file used for creating/editing a profile in the DNG Profile Editor
.dcp—camera profile
.lcp—lens profile"
PS... The OP's K5 does not work with K5 ll or llS
Personally I start with the camera's embedded profile and start my flow in ACR from there. If I need to adjust color then I adjust via HSL/Grayscale tabs.
