07-02-2014, 07:07 AM   #1
KRaZiGLiTcH's Avatar
Pentax K-5 + Vivitar 1900
Hi guys just wanted to ask you's a question I bought an old film camera that came with a vivitar 1900 Flash and I used it on my k-5 with only 2 shots and did not realise that you have to make sure the voltages are safe,Yeah... Well will my K-5 be ok now ? As its acting normal and turning on and taking photos. Of course I wont be using the vivitar anymore
07-02-2014, 07:14 AM   #2
boriscleto's Avatar
The Vivitar 1900 has a trigger voltage of 90V, or 123V depending on who tested it. That is higher than the recommended max from Pentax (20V). I wouldn't use it on anything but a wireless slave.
07-02-2014, 07:15 AM   #3
QuoteOriginally posted by boriscleto Quote
Yes i know but will my K-5 be fine now like it won't die on me will it ?
07-02-2014, 07:17 AM - 1 Like   #4
boriscleto's Avatar
People have used flashes with higher trigger discharges than that and not fried the camera. If you didn't fry the camera the first time you used it you should be fine.
07-02-2014, 07:20 AM   #5
Thank you so much,I have been freaking out so much.
I feel super stupid now though
07-02-2014, 08:10 AM   #6
OregonJim's Avatar
It sounds like you were lucky. But, it's still possible that you fried the hotshoe connection even though the camera works otherwise - the only way to be sure is to try using a (safe) flash unit.
07-02-2014, 09:19 AM   #7
VisualDarkness's Avatar
If the camera still works as it should then it's most likely just fine. Electronics are a bit random at times with how much they can take, just don't use it again.
07-02-2014, 03:27 PM   #8
QuoteOriginally posted by OregonJim Quote
That's just great,I can't test it as i haven't got a flash yet.
thanks
QuoteOriginally posted by VisualDarkness Quote
That's true and no i will not thanks.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, pentax k-5 vivitar, vivitar
Vivitar 3.5 35-200 P/K A adapter for K-r boojum Pentax K-r 5 03-23-2014 02:25 PM
New Firmware for K-500, K-50, K-5 II, K-5 IIs, K-5, K-30, K-01, K-r, and 645D is out Adam Pentax News and Rumors 60 09-16-2013 05:46 AM
K-mount Vivitar 70-210 F3.5(kenko) on my pentax K-x emmbeepentax Troubleshooting and Beginner Help 4 06-14-2011 08:18 PM
Vivitar 28-105 f/3.5-4.5 lenses for Pentax K-x lacta345 Pentax DSLR Discussion 5 12-11-2010 01:52 AM
All times are GMT -7. The time now is 09:02 PM. | See also: NikonForums.com, part of our network of photo forums!
