07-08-2014, 12:10 PM   #1
Connect K5 to MacBook Air/projector
I will be teaching a class this fall and would like to be able to connect my K5 to a MacBook Air w/ USB2 and Thunderbolt connections. My goal is to be able to show lighting and to show completed images (small JPEGs) to a class of 10 or so students. Has anyone done this, and if so, what cable(s) did you need to make it work? Also, did you need any particular software on the computer or firmware update on the camera? Thanks in advance.
07-08-2014, 02:40 PM   #2
boriscleto's Avatar
A lot depends on the projector. If the projector has HDMI you can just connect the camera to the projector using the HDMI port. You can get an adapter for the MacBook to connect to whatever other input the projector has, but the projector may have an USB connection (needs a driver installed on the MacBook).
07-08-2014, 03:05 PM   #3
Paul the Sunman's Avatar
The most common connection for projectors is vga, for which you need a mini-display port to vga connector. Mini DisplayPort to VGA Adapter - Apple Store (U.S.) But check, you may need dvi or something else instead of vga, depending on the projector.
07-08-2014, 03:14 PM   #4
Miguel's Avatar
Couldn't you just insert the SD card from the camera into a USB card reader attached to the MacBook? Or copy the images from your post-processing software to a SD card and then use the USB card reader?
Or are there settings on the camera you want to use in the classroom presentation? That would explain your desire for a direct connection.
M
QuoteOriginally posted by Cascadilla Quote
07-11-2014, 02:35 AM   #5
EssJayEff's Avatar
Start with the projector and see what options that particular model offers. Such as ports and card slots. Models differ.
camera, class, dslr, k-5, k-5 ii, k-5 iis, k5, k5 to macbook, macbook, pentax k-5
Error Tapatalk on windows phone unable to connect to pentaxforum raider Site Suggestions and Help 4 07-19-2013 04:16 PM
how to connect x-5 to computer LynneBH Pentax Compact Cameras 4 06-22-2013 02:35 PM
Verizon 4G LTE Personal Hotspot on the New iPad 3rd Gen with MacBook Air and iPod 4G jogiba General Talk 2 07-19-2012 03:00 PM
MacBook air and 645d files Fontan Pentax Medium Format 9 09-12-2011 10:56 PM
Macbook Pro vs Macbook Air Mr_Canuck General Talk 6 04-15-2011 10:07 PM
All times are GMT -7. The time now is 04:26 AM. | See also: NikonForums.com, part of our network of photo forums!
