07-20-2014, 08:16 PM   #1
Is there a better way?
Set up a USER configuration on my K5.
The problem is now I have to switch between TAv and USER with the mode dial.
It's just too slow and clumsy for my kind of shooting.
Is there a better faster way to have two separate modes more or less instantly available?
07-20-2014, 10:26 PM   #2
You could buy another K-5 body
Honestly though, too slow to change mode dial. Really?
Besides if there was a way, the mode dial would no longer be in sync with the mode its in.
07-20-2014, 11:21 PM   #3
MarkJerling's Avatar
QuoteOriginally posted by wildman Quote
You could set up two user modes, one set as your favourite TAv setup, the other with the different user setting. It's quick to go from one user setting to another without touching the mode dial. (You can set up to 5 user modes)
07-22-2014, 04:53 PM   #4
QuoteOriginally posted by MarkJerling Quote
How?
The only way i could find was to go into the menu system but maybe I'm just being thick about it and missing something.
07-22-2014, 08:49 PM   #5
How?
Yes, I use the menu system. Pretty quick once you're used to it.
08-08-2014, 06:57 PM   #6
zekewhipper's Avatar
How can you change USER modes through the menu?
08-08-2014, 07:18 PM   #7
fgaudet's Avatar
Too slow, really? What are you shooting that requires radical camera settings in such a hurry? It takes 4 clicks one way to get to switch from Tav to USER, and 4 clicks the other way to get back. I can easily switch from one mode to the next in far less than a second without even looking away from the viewfinder.
You could always get a K3, you'd have three user modes on the dial, only one click in between each. And if you'd disable the dial lock it'd be even easier
---------- Post added 08-08-14 at 22:23 ----------
QuoteOriginally posted by zekewhipper Quote
Hit "MENU", item one in the first menu is the user selection. Fairly easy, Menu, Down, Right and then up/down to choose
08-14-2014, 06:02 PM   #8
QuoteOriginally posted by fgaudet Quote
Thanks for answering! (I was a bit slow.)
08-16-2014, 07:59 AM   #9
Ah, no. It's File Format.
08-16-2014, 08:09 AM   #10
fgaudet's Avatar
Your mode dial has to be on "USER", we're talking about switching user mode here
08-16-2014, 06:37 PM   #11
Okee doekee.
camera, clicks, dslr, k-5, k-5 ii, k-5 iis, k5, menu, modes, pentax k-5, photography, switch, user
Is there a way to sync over 1/125? bcroslin Pentax Medium Format 8 10-24-2013 12:06 AM
Question Is there a way members could rent equipment? sholtzma Site Suggestions and Help 7 07-30-2013 08:09 AM
Is there a way to limit maximum shutter speed? steppenfuchs Photographic Technique 20 05-04-2013 12:25 PM
Kx Remote - Is there a better idea out there? jwiles Pentax DSLR Discussion 13 07-20-2010 06:51 PM
Is there a better way to navigate the Pentax Photo Gallery? iocchelli General Talk 7 06-28-2010 09:04 PM
All times are GMT -7. The time now is 05:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
