12-04-2014, 12:43 PM   #1
Tracking with K-5 II and DA*300
Hello
I own the K-5 II and recently purchased the DA*300 f4.
Since i dont have experience in long telephoto. (Till now i used only the DA* 50-135 f2,8.)
Can someone explain me how to correct lock and track a fling object ?
What should I avoid and how to correctly set the camera for this.
Any help will be helpful.
Thanks for info.
12-04-2014, 01:09 PM - 1 Like   #2
boriscleto's Avatar
Use AF.C and multi-point AF and set drive mode to Hi continuous. Turn shake reduction off if you are going to be panning at all. Set the shutter speed to at least 1/1000s. Take lots of pictures, one is bound to be in focus...
12-05-2014, 01:15 PM   #3
QuoteOriginally posted by boriscleto Quote
Thanks. I will try it and share some results.
12-12-2014, 08:24 AM - 1 Like   #4
stormtech's Avatar
There is a setting in the K-5II/K-5IIs to enable focus tracking.
In the menu - first page - go to AF Settings - then you need to check the box for "Expanded Area Focus".
Explained on page 115 of the manual in the gray box.
camera, da*300, dslr, ii, k-5, k-5 ii, k-5 iis, k5, pentax k-5
For Sale - Sold: K-5 II with DA 40mm 2.8 xs or will sell separate ChuyQ Sold Items 10 12-04-2013 08:02 AM
New Firmware for K-500, K-50, K-5 II, K-5 IIs, K-5, K-30, K-01, K-r, and 645D is out Adam Pentax News and Rumors 60 09-16-2013 05:46 AM
Flickr not differentiating between K-5, K-5 II, and K-5 II s Corby Pentax K-5 5 04-27-2013 04:05 PM
k-5 II and AF on DA 55-300mm Zoom Lens caravan Troubleshooting and Beginner Help 7 04-22-2013 09:01 AM
K-5 ii vs K-5 iis comparison with higher sharpness in K-5 ii kataria0 Pentax K-5 62 12-22-2012 10:12 PM
All times are GMT -7. The time now is 07:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
