12-19-2014, 04:48 AM   #16
That small hole on top is a puzzle.
It's clearly not there in the K-3 body:
as evidenced by a K-3 cutaway:
12-19-2014, 05:01 AM   #17
Digitalis's Avatar
That small hole on top is a puzzle. It's clearly not there in the K-3 body:
They moved it to the front of the camera body...it could possibly be a mono mic* - the wiring is a bit scrambled in the cut away model, but if you look closely the red/white wires are a dead giveaway.
*though it is a bit odd place for a pic: doesn't the K3 shoot video with stereo audio?
12-19-2014, 07:10 AM   #18
My original thought is that it was a simple air vent on the K-5 (for air pressure relief with WR zooms, for example). Maybe with the K-3 they relocated it somewhere else. But it seems too small to be effective as a vent.
12-19-2014, 08:45 AM - 1 Like   #19
mrNewt's Avatar
QuoteOriginally posted by Dartmoor Dave Quote
Those shots of the stripped-down K5 chassis show how small the pentaprism hump could be without the silly pop-up flash. Personally I never use the little pop-up toy, and I don't think it's necessary on a top-of-the-range camera.
It doesn't mean other's don't use it...
In a pinch, you can use that little "silly pop-up flash" to trigger other external flashes without the need of a wireless trigger.
It has its uses and on a "pro-level" camera makes even more sense... when you want all the options possible for the "just in case" situations.
12-19-2014, 08:54 AM   #20
LensBeginner's Avatar
QuoteOriginally posted by mrNewt Quote
Yep, I concur, it's definitely there to save your back when you need it.
Besides, if you know how to use it/shape its light it's not too bad for an emergency solution...
12-19-2014, 09:01 AM   #21
mrNewt's Avatar
QuoteOriginally posted by LensBeginner Quote
You can get very good results if you use the little flash as a small fill in light while triggering your "main light / external flash"... and voila... 2 light setup and all you need is an external flash. I have to admit I use this setup when I'm on the go quite a lot.
No need for triggers or anything else .
12-20-2014, 02:40 AM   #22
Dartmoor Dave's Avatar
Although Canon, Nikon, Sony, Leica (et al) don't include pop-up flashes on their "pro-level" cameras. And I'd expect it to be absent on the Pentax "full frame" when it finally surfaces -- hopefully in a couple of months.
12-20-2014, 03:09 AM   #23
So, if everyone does that, it must be the smart thing to do, right?
12-20-2014, 03:44 AM   #24
As it's clearly what that specific market expects, then yes, it's the smart thing to do. And it would be dumb to produce an entry-level DSLR without a pop-up flash, because of the different expectations in that market.
12-20-2014, 05:01 AM   #25
Digitalis's Avatar
I can't tell you how many times I have heard of annoyed professional Canon users who with XD camera bodies complain that they have to buy an external flash or a flash commander to control wireless groups, while users of entry level bodies users get the built in flash to do it for them.
12-20-2014, 08:59 AM   #26
mrNewt's Avatar
Then that will be one more reason to be less interested in a Pentax camera.
If I wanted a Nikon or Canon I would of bought one...
And sorry to brake it to you, but there is no such thing as a pro camera. There are just cameras with different options and settings.
There are pro photographers and whatever gear they chose is just a camera with the option they want and need the most, based on their work flow. Whatever works for one doesn't work for others.
I like options and I like what Pentax has to offer. And on their "pro-level" cameras like K-5, K-01, K-3 or Q series, that pop-up flash is very useful for me.
12-21-2014, 04:08 AM   #27
Depending on your definition of 'pro', most Nikon current FF's - the D600/610, D750, D800/E, D810 - have built-in flashes. The only current FF models that don't are the D4s and Df.
IMHO, if it's good enough for the D750/D810, a built-in flash will be good enough for a Pentax FF.
It's true that every Canon FF from the 6D upwards lacks built in flash. And it's true that the only current Sony FF with a built-in flash are the RX-1 models. But I'd prefer Pentax follow Nikon's path on the matter.
Built-in flash is useful not only for convenience and fill, but also as a handy wireless flash controller, as others have noted.
12-21-2014, 04:52 PM   #28
Otis Memorial Pentaxian
It is also great for eating battery capacity!
12-28-2014, 07:51 PM   #29
Those stripped pics are amazing. How cool it is to see inside it like that. It really makes you appreciate how well these cameras are built, doesn't it?
12-29-2014, 10:43 AM   #30
TER-OR's Avatar
how about a trio of 1W LEDs instead of or in addition to a strobe - bright enough to be a headlight... with variable output it could be an easy video light.
I do agree that the pop-up flash needs a lock, I've often bumped it open when walking around - I use a sling strap, and the camera hangs upside-down.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5
The LBA is weak. 6BQ5 Pentax SLR Lens Discussion 26 08-04-2014 12:18 PM
Rusted Chain Link Gareth.Ig Monthly Photo Contests 0 04-30-2012 05:54 PM
Macro Not for the Weak Stomach! Bramela Post Your Photos! 11 12-14-2010 07:35 AM
Abstract Chain Link Aventure tatum.brennan. Photo Critique 7 10-03-2010 09:55 PM
Two hunters in the sand ... not for you weak hearted Rense Post Your Photos! 13 08-13-2009 11:41 AM
All times are GMT -7. The time now is 06:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
