01-27-2015, 05:31 PM   #1
Freaky Highlights?
I'm brand new to Pentax but been shooting pix for many many years. I have been getting these weird sparkly highlights on many of my photos. I thought it might be a setting on the camera so I reset it to factory. Still occuring .. so I took this with the auto setting just to see what the camera thought it should do and I still get blown out highlights. The camera for the most part errs on the side of over exposed. Someone suggested that the issue could be a non stock focusing screen. I bought the camera used. Could that be causing the sparkles?
I posted the image here. Its pretty big
http://www.boriqualeather.com/IMGP1224.JPG
01-27-2015, 05:46 PM   #2
Are you shooting raw? or jpeg.
---------- Post added 01-27-15 at 07:59 PM ----------
I just saw in your other posts you bought a Sigma 50mm macro..If you took your picture with that lens A diffuser for the light source is needed. My sigma-A 50mm does that in harsh light.
01-27-2015, 06:01 PM   #3
mattt's Avatar
I think it is a result of harsh light. Under the conditions you're shooting with, a scrim would be very helpful. The dark subject matter with specular highlights from the texture of the leather create too much dynamic range. There is a member here who shared a bunch of product shots of jewelry. If I recall correctly the thread might be very helpful to solve your problem.
EDIT - Found the thread Here
01-27-2015, 06:10 PM   #4
If you're using the K-3, make sure the high ISO noise reduction is turned off. along with any other automatic enhancement feature. if that corrects your problem, You can turn on one or two features at a time, to see which feature created the problem.
01-27-2015, 06:13 PM   #5
QuoteOriginally posted by promacjoe Quote
Its a k5 I peeked in his other posts.
01-27-2015, 07:12 PM   #6
amoringello's Avatar
Focusing screen has no effect on what the actual sensor sees.
Are you talking about the tiny specs on the subject (appears to be textured leather)?
That is just the shiny textured surface reflecting the light source.
As mentioned a more diffuse light (i.e. larger compared to the size of the subject) will help. Or a polarizer on either the flash or on camera might also help a bit.
It would be interesting to see another example. i.e. if you are see this on different materials with properties where one would not expect this behavior.
01-28-2015, 04:21 AM   #7
Class A's Avatar
QuoteOriginally posted by amoringello Quote
True, however non-stock focusing screens are known to be capable of causing overexposure, in particular when using spot metering.
I would suggest to use manual negative exposure compensation and a softer light source. It would also make sense to check the metering mode and perhaps set it to matrix metering for scenes such as the above.
01-28-2015, 05:20 AM   #8
Just looks like reflections off those parts of the polished leather that are angled in such a way as to reflect the light from the window (or whatever the light source to right of the image is) straight towards the lens. The light source is very bright compared to the general ambient lighting as can be seen from the bag's deep shadow on the table.
As others say, a diffused light source is really needed for such photography - one of those soft boxes cubes for product photography would help and the shot would also benefit from two light sources - one each from left and right to give more even lighting on the bag.
50mm, camera, dslr, k-5, k-5 ii, k-5 iis, k5, light, pentax k-5
People Freaky eye Lucky-Luc Photo Critique 7 01-14-2014 05:23 PM
Pentax K-3 highlights GrinMode Pentax News and Rumors 216 10-31-2013 10:22 AM
Nature Pampas Highlights ozwald Post Your Photos! 2 08-27-2013 06:54 PM
Travel Highlights from Europe chunhin Post Your Photos! 3 08-12-2013 01:19 AM
Freaky Friday at Buy.Com 13% Cash Back Docrwm Pentax Price Watch 3 04-13-2012 07:36 AM
All times are GMT -7. The time now is 09:53 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
