01-30-2015, 10:02 AM   #1
Flash Trigger
Does anyone know of a flash trigger that works with the k5? I just got the Yongnuo RF-603 (Version I) and I can get it to work.
01-30-2015, 10:11 AM   #2
jatrax's Avatar
Wireless? I use Cactus v5 and they work great. I would get the Cactus v6 (newer) ones now. But the Yongnuo should also work, many here use them.
  • Is your camera's shutter speed below 1/180? Try it in x-sync mode.
  • Do you have the triggers on the same channel?
  • Does the trigger fire the flash when not on the camera? Use the test button.
  • Batteries in the right way?
01-30-2015, 10:16 AM   #3
THoog's Avatar
QuoteOriginally posted by jcraun Quote
RF-603C or RF-603N? Only the N (Nikon) version works with Pentax bodies. The C (Canon) version won't work with Pentax because the pins don't match up for it to get a wake up signal.
01-30-2015, 01:25 PM   #4
RAART's Avatar
NPT-04 from Cowboy Studio are basic triggers and works like charm. I never tested the distance but for my purpose around 10-15m was always working. They are also very cheap and I have them for very long time (at least 2 years) and never failed me. Works with any camera with hot shoe or PC sync cable.
Check what Jatrax said... The shutter speed should be bellow 1/180s otherwise will not work.
BTW on Olympus E-PL1 the NPT-4 triggers works past 1/180s but around 1/300 and higher you will see the shutter in the pictures... Wish Pentax did not put limitations on the hot shoe.
01-30-2015, 01:39 PM   #5
Bengan's Avatar
I have had good results with the Commlite Comtrig T-320. I hav e also worked with the 603 (Nikon). The reason I ended up with the T-320 is that i passes TTL through to a a flash mounted on the transmitting unit.
01-30-2015, 03:12 PM   #6
Hi
Yongnuo RF603-11N mine worked with my K5 straight from the box. As already stated only nikon fit works with Pentax.
01-31-2015, 03:31 AM   #7
Thanks
Thanks for all the great feedback. I just ordered the Nikon version. One note though. The shutter cable from Nikon does not work. I already have the canon one that does.
camera, dslr, flash, k-5, k-5 ii, k-5 iis, k5, pentax k-5, rf-603c, trigger
Help with Yongnuo Flash Trigger Classpro Troubleshooting and Beginner Help 5 01-11-2015 12:53 AM
cactus V4 Flash Trigger rollin Troubleshooting and Beginner Help 5 12-12-2014 02:33 AM
K3 flash trigger problem UKAndre Troubleshooting and Beginner Help 4 11-27-2014 01:38 PM
Sugesstion flash trigger kits K5_Ltd_User Flashes, Lighting, and Studio 19 04-24-2014 01:00 AM
Recommend a wireless flash trigger please! liukaitc Pentax Camera and Field Accessories 17 08-09-2011 06:21 PM
All times are GMT -7. The time now is 09:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
