03-23-2015, 08:54 AM   #1
Stabilization with manual lens
Hello. I have a photo student who is using the Pentax K5II. She has put the Rokinon 500mm f/8 mirror lens on this camera using a T2 adapter. However, she insists that there is no way that "handshaking" or image stabilization can be used with this lens, saying that the camera goes to manual mode only, as opposed to Aperture Preferred Automation, which is what I suggested to her, and that handshaking won't work with the mirror lens. I thought I'd check here to see if this was actually the case. I use an Olympus OMD E-M1 which I use with a Tokina mirror lens. Both image stabilization and aperture preferred automation work with my mirror lens. Thank you for your help.
03-23-2015, 09:02 AM - 1 Like   #2
boriscleto's Avatar
If SR is turned on, you simply input the focal length when the camera is turned on. You can also change the focal length in one of the menus.
As the lens if a fixed aperture lens, it can be used in AV mode. You just have to turn on "Using Aperture Ring" in the custom menu.
https://www.pentaxforums.com/forums/58-troubleshooting-beginner-help/110658-u...x-dslrs-f.html
03-23-2015, 09:52 AM   #3
vagrant10's Avatar
If the lens and camera are mounted on a tripod, it is suggested you turn off the shake reduction as being on a stable platform will cause the camera to try to correct for movement that isn't there resulting in a blurry shot (counter intuitive as that may seem...)
03-23-2015, 12:04 PM   #4
Thanks
Thanks for the feedback about using a manual T2-mount lens on the K5II. I've passed that on to my student. I'll go through the menu steps with her and see if we can get the lens to work with AV and shake reduction. This lens will not be mounted to a tripod. The purpose is to enable shake reduction for camera motion blur-free handheld long telephoto shots with the unique mirror lens bokeh. Like this:
03-23-2015, 01:04 PM   #5
QuoteOriginally posted by Hanknj2 Quote
That's very funky. I like it.
03-23-2015, 01:52 PM   #6
It is true they won't get "handshaking", but that won't prevent use of SR. And with that lens, handshaking wouldn't serve much purpose since it has no aperture mechanism (you lose matrix metering and aperture/lens data listed in the EXIF, but that's all). Just put it in Av and enter the focal length when it asks (it should ask when you turn it on if you are in normal drive mode) and you're good to go. (You might have to set "enable aperture ring", but not sure if you have it in Av.)
03-24-2015, 12:38 PM   #7
TER-OR's Avatar
Hand-shaking as in the lens and camera communicating? Not if it's manual, there's nothing to communicate.
Reduction in hand shake via in-body image stabilization? Yes, that still works.
aperture, camera, dslr, handshake, image, k-5, k-5 ii, k-5 iis, k5, lens, mirror, mirror lens, pentax k-5, stabilization
K Mount lenses with Image Stabilization? ZombieArmy Pentax SLR Lens Discussion 10 09-04-2014 12:29 AM
Trouble with Stabilization & Firmware tjdean01 Pentax Q 4 05-14-2014 11:01 AM
Image Stabilization with manual lenses and adapter CDW Pentax K-5 4 06-25-2013 07:33 AM
Image stabilization and manual SMC A series lenses Rusty Rat Pentax DSLR Discussion 32 01-18-2010 03:45 PM
In-body stabilization + lens stabilization ntx Troubleshooting and Beginner Help 14 02-24-2009 05:24 PM
All times are GMT -7. The time now is 02:34 PM. | See also: NikonForums.com, part of our network of photo forums!
