03-27-2015, 05:42 AM   #1
dakight's Avatar
Minimum ISO
My K-5 IIs arrived yesterday and I'm getting acquainted with it but I've run across one thing so far that I haven't been able to figure out. When the camera is in Auto ISO mode, I cannot set the minimum ISO below 200; I would prefer it at 100. Is this normal or am I missing a setting somewhere?
03-27-2015, 05:59 AM   #2
Chaos_Realm's Avatar
you'll need to select expanded sensitivity from the menu
03-27-2015, 06:00 AM   #3
gwboes's Avatar
got to menu, C, and point 3 should probably say extended sensitivity (my camera is in Dutch so I don't know the exact translation). If you turn that on you can go as low as ISO 80.
03-27-2015, 06:04 AM   #4
max_pyne's Avatar
if i remember right its due to highlights and shadow limits / correction or one of those other corrections . if you turn those off it should work
03-27-2015, 06:06 AM   #5
dakight's Avatar
Did that and now I can get down to ISO 160 but it refuses to move below that. I tried a couple of different lenses and it's the same with both.
03-27-2015, 06:08 AM   #6
what shooting mode are your in?
03-27-2015, 06:16 AM   #7
dakight's Avatar
OK. I probably should have done this as soon as I got since it was a used camera: I just did a reset to defaults and it's working as expected now. Something in some obscure menu was probably set. Now I'm starting with a clean slate. Thanks for the quick responses.
03-27-2015, 06:17 AM   #8
gwboes's Avatar
If i'm correct turning on highlight and shadow compensation changes the min/max ISO values. Try turning these functions off.
03-27-2015, 06:29 AM   #9
dakight's Avatar
QuoteOriginally posted by gwboes Quote
That may have been what it was. Those were turned on. At any rate, it's working good now. Thanks.
03-27-2015, 06:45 AM   #10
StephenHampshire's Avatar
QuoteOriginally posted by dakight Quote
Highlight protection, if on, doubles minimum ISO - so 200 or 160 with expanded ISO on
camera, dslr, iso, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Minimum ISO... Sensor experts? soycory Pentax DSLR Discussion 32 01-06-2015 11:11 AM
Setting minimum shutter speed? yakky Pentax K-30 & K-50 5 12-08-2013 09:33 AM
K-x minimum ISO rating ranmar850 Troubleshooting and Beginner Help 3 12-16-2012 06:57 PM
Aperture + *minimum* speed -> iso ?? FixB Pentax DSLR Discussion 6 04-18-2011 06:58 AM
Standard minimum ISO 400 on K-x tebitan Pentax DSLR Discussion 8 12-12-2009 12:26 PM
All times are GMT -7. The time now is 10:10 PM. | See also: NikonForums.com, part of our network of photo forums!
