04-06-2015, 09:46 AM   #1
How do you deal with mirage & atmospheric effects?
Hey gang,
Hoping to tap into some experience here on the forum. As the title says, how do you deal with mirage & atmospheric effects with a long tele over water?
I'm not running any filter, this is with my K5 classic, and Tamron SP AF 70-200 2.8 lens, no filters on the front element.
Here are some samples that show the effect. The first pic is uncropped and doesn't show the effect as bad but it's still there, the next are all 100% crops, which I needed because I forgot my 1.4x, and even then it wouldn't have been long enough.
What would you do differently to get more clarity with less influence from atmospheric conditions? Not sure how our old film filters would work, and I figure it's too late to fix in post after it is captured.
Part of me is wondering if the K5IIs without the AA filter handles this better or worse? Also thinking more pixels would be nice, might not have to crop so much and loose so much detail... will a longer tele make the effect worse? I see shots from similar events that look good, so I know it can be done. What is the trick?
I did do some post, mostly just corrected the white balance, (OOC was leaning towards magenta's) removed some noise, tiny bit of unsharp mask etc.
Thanks in advance for any and all replies.
04-06-2015, 10:00 AM - 1 Like   #2
QuoteOriginally posted by Erictator Quote
You could shoot in the vacuum of space, but then there would be no wind for the kite surfers sails.
Sadly, any amount of atmosphere between you and your subject has the potential to both scatter and refract light. The scattering reduces contrast and sharpness. The refraction distorts. A polarizing filter can help with the scattered light, but you are still stuck with the refraction (mirage) problem.
The solution is to move closer to your subject. The more atmosphere between you and what you are shooting, the worse things get.* In the case of a munged background, there is nothing you do.
* This is the source of recurring questions on this site where the user can't understand why their expensive lens is soft for distant subjects.
04-06-2015, 11:19 AM   #3
jatrax's Avatar
Shoot on a different day. Higher humidity tends to increase the problem. Dry and cold reduces it. But it never goes away, unless you go with Steve's idea and only shoot in space. Time of day can be vastly different, an early morning might give you fairly clear shots, but a few hours later nothing but haze.
I have read claims that a UV filter will help reduce the haze but I have not been able to confirm that from personal experience. There are also some post processing techniques that claim to help such as adjusting the color channels separately in Lightroom or Photoshop. I tried that once with limited success. Adding clarity and contrast and reducing the blue with the targeted adjustment tool in Lightroom can help but bottom line there is no easy 'fix'.
04-06-2015, 12:29 PM   #4
RuiC's Avatar
As haze is reflection on vapour in the air wouldn't a polarizing filter help reduce these reflections ??
04-06-2015, 12:40 PM   #5
QuoteOriginally posted by RuiC Quote
As haze is reflection on vapour in the air wouldn't a polarizing filter help reduce this reflections ??
Yeah, before I plunked down my hard earned cash to gamble on any filters, I was hoping for some endorsement or direction on the idea.
Especially with my Tamrons' huge front element 77mm filter thread, a good quality polarizer for instance, won't be cheap!
Eric
04-06-2015, 01:31 PM   #6
crewl1's Avatar
Maybe test it by placing your polarized sunglasses over the front of the lens and even if it covers only part of the view you may notice if there is a difference in the shoreline.
04-06-2015, 03:10 PM   #7
narual's Avatar
Polarization.com
can grab some of that to test it out with, and then use it later to polarize your flashes/studio lights if you ever need to
04-06-2015, 08:35 PM - 1 Like   #8
RAART's Avatar
This might be solution for you, though I never tried by myself... Good luck and share your results!
Kolor | Neutralhazer - Anti-haze plugin for Photoshop
04-07-2015, 03:31 PM   #9
jatrax's Avatar
QuoteOriginally posted by RAART Quote
That looks pretty amazing. Might be useful making masks for blending in new skies as well. Very interesting.
04-08-2015, 08:37 AM   #10
Thanks, I have similar tools in Photoshop already... and they can clear up the haze, but to fix the water color impressionist looking smears from the moisture in the air, I think I'm going to have to try a polarizer, nothing in post-processing is going to bring the detail back.
Obviously spy satellites that can read the note in your hand can go through miles and miles of atmosphere, so there has to be a way to do it.
Eric
04-08-2015, 11:20 AM   #11
crewl1's Avatar
Eric
Haze may be a few hundred feet thick but when viewed from land across the horizon you could be looking through miles of it.
Or maybe more than a few hundred feet but it stays close to the ground.
I see smog and haze appear as a layer over my town during some times of the year when landing from a flight.
It has a visible top edge and does not go up miles into the atmosphere.
camera, dslr, effect, filter, filters, flickr, k-5, k-5 ii, k-5 iis, k5, mirage, pentax k-5, tele
Question How do I deal with a forum seller of obvious trash? aoeu Site Suggestions and Help 2 10-29-2014 02:10 PM
How do you deal with your models? micromacro General Photography 27 09-07-2014 04:48 AM
How often do you have a tripod with you? Vylen Pentax Camera and Field Accessories 60 10-02-2013 04:33 AM
Grainy, atmospheric B&W with the K-5 ronpyke Pentax K-5 10 11-22-2011 01:47 PM
Freckles! How do you deal with them? metroeloise Post Your Photos! 18 06-02-2009 09:37 PM
All times are GMT -7. The time now is 09:23 PM. | See also: NikonForums.com, part of our network of photo forums!
