Hi.
I don't use flash much, but it was necessary today. I had used the mounted flash for a few pictures (TAv), and that went fine. Then later I was taking a couple that needed fill flash, and I just used the on-camera flash. For some reason (still TAv) it kept opening the aperture by a stop or more after each picture. I figured I must have hit something, but I have no idea what. All the settings seemed normal. I took the battery out for over a minute, but it continued to do this so long as I used the flash, causing massive overexposure if I didn't reset the aperture after each shot. I did not have the shutter speed too high for the flash.
Does anyone know what setting I inadvertently hit to cause this?
