08-10-2015, 02:51 PM   #1
Three blinking lines/dots in K-5IIs viewfinder
Hi,
I recently got a lightly used K-5IIs and I notice every now and then when looking through the viewfinder I see 3 blinking lines/dots (where the electronic level display/exposure is). Does anybody know what that means? When I disable the electronic level I do not see it anymore. I thought it was to tell me the camera is level but sometimes when it is level I just see 1 line/dot in the middle and other times it is those 3 blinking lines (1 at each end of the meter and 1 in the middle). I don't know if it has to do with exposure or low light? Thank you.
08-10-2015, 03:29 PM   #2
chromo's Avatar
I means the camera angle cannot be detected.
08-10-2015, 03:46 PM   #3
If the angle is outside of the level's display range (3 degrees), then that's what you'll see.
Also, if the level is giving you a hard time, try updating the camera's firmware.
08-10-2015, 08:18 PM   #4
Put the camera down carefully and run!
08-10-2015, 10:33 PM   #5
Thanks for the replies. I have the latest firmware already installed (1.07).
camera, dslr, k-5iis, level, lines/dots in k-5iis, middle, photography, viewfinder
Blinking flash indicator in Av on K-5 Sal R Troubleshooting and Beginner Help 9 12-18-2014 10:48 AM
Abstract Drops, lines, dots causey Post Your Photos! 2 12-31-2013 12:44 PM
just received my K-5 , dots on viewfinder kamisu Pentax K-5 53 03-26-2012 09:50 AM
What is the blinking F -- in the viewfinder/lcd??? jack56 Pentax DSLR Discussion 7 07-05-2009 12:35 AM
K-m viewfinder shows patterned dots duping812 Pentax DSLR Discussion 11 03-27-2009 11:19 AM
All times are GMT -7. The time now is 10:10 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
