10-24-2015, 02:22 PM   #1
BillR's Avatar
k5 white balance on green mode
Interior natural daylight lighting. Auto white balance on green mode (auto) is accurate. On EVERY other setting (P, Sv, Tv, Av, TAv) it is so far off it's pitiful. I've checked all my color settings and I can't find anything unusual. I have also reset to default settings and that makes no difference. Anyone have any idea what's wrong, if anything?
10-24-2015, 02:48 PM   #2
Na Horuk's Avatar
Are you sure you have AWB selected in the other modes, as well? Its possible that another mode, like Av, has its own WB setting memorized, one that doesn't adjust
The other thing to check is the jpeg mode. Press Info, then select Bright, Vibrant, Portrait, Landscape, whatever. Some of these change the colours a lot (like film reversal, its not bad).
Hm, interesting problem. Maybe someone who has a K-5 can run a test to see if theirs does anything suspicious, as well.
10-26-2015, 01:51 PM   #3
BillR's Avatar
Thanks for the reply. Yes. AWB is selected for all modes. I almost always shoot RAW. But I tried jpeg and same problem. It's easy enough to correct the color in post processing. Maybe a software problem?
auto, balance, camera, dslr, interior, k-5, k-5 ii, k-5 iis, k5, k5 white balance, mode, pentax k-5, settings, white balance
K5 white balance problems ryan.wadsworth Pentax K-5 6 01-21-2014 11:53 PM
Auto white balance in M mode kakapo Pentax K-01 5 05-03-2013 01:04 PM
Manual white balance problems on K5 2grahamb Pentax K-5 10 09-29-2011 01:06 AM
Kx white balance in video mode hydroclops Video and Pentax HDSLRs 6 02-25-2010 11:36 AM
Green cast to white balance gatekeeper Pentax DSLR Discussion 8 01-09-2009 05:36 PM
All times are GMT -7. The time now is 11:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
