11-15-2015, 09:25 PM   #16
bkpix's Avatar
No one has mentioned the Dust Alert feature in the K-5 menu. (p4 of the wrench menu.) It sets up the image for you.
Dial it up, point the camera at something reasonably bright and white, and take a photo. It processes the image to amplify any dust issues -- and flips it, so the image is oriented the same way as the camera sensor as you look at it from the front. In other words, if the dust is in the lower right corner of the image, it's in the lower right corner of the sensor, not upper left.
11-15-2015, 10:32 PM   #17
QuoteOriginally posted by Dabola Quote
Today I read this old thread and many comments about sensor problems in early series of K5. Exiftool tells me that my second hand K5 is produced the 23rd of Oct 2010. Serial number is 38619X. On this list of serial numbers I can see many other menbers of this forum mention stain problems with serial numbers close to mine.
I've not noticed anything. Nor have I made any professional test. What's the optimal way to check my camera for stain(s)? Up in the northern Norway blue heaven is uncommon these days of the year. White paper on the wall, hang up the paper in front of a reading lamp or? Is 35mm 2.4 optimal or? Iso 80? Clean computer screen or software-test?
For me the best and simplest way is take a new sheet of copier paper. Use any lens you wish, hold the paper in front of the lens and take a couple of shots. Then go ahead and transfer the photo onto your computer. If there is dust on the sensor, you will notice small, round spots on the image. If you have a magnifying glass it will help to pick up on the smallest of spots. Good luck and hope this helps.
Tonytee
11-16-2015, 06:58 AM   #18
Thanks to all of you for many good advices. BrianR and SteveBr, you are right;
...The thing you're aiming at doesn't need to be in focus at all - the more you stop down, the more the dust will show up.
...create the sharpest shadow of the dust at the sensor.
bkpix
, you've found way to do it; K-5's own tool, Dust Alert feature - by the Set-up menu. I was not aware of this tool. Perhaps because this alternative is grayed out when Manual Focus is selected.
Like you, Tonytee, I held a new sheet of copier paper in front of a reading lamp and made a shot. A picture is taken (saved for 30 minutes). With a magnifying glass I could see the grid of pixels. Repeat this process 2-3 times. (The 1st time I discovered two spots which was not visible the 2nd time). Without the paper the light is too intensive and I got further false spots.
Nice to get verified that the sensor in my second hand K5 is as clean as a child butt - as we say in Norway.
Thanks to this forum! I learn all the time... Finally; here's a printscreen from the manual:
11-16-2015, 10:35 AM   #19
BigMackCam's Avatar
Yes, you're right of course I guess I use the LR6 visualise spots function because I can do it the same way for my K3, K5 and Q7 (and any other camera I may end up with in future)... Plus, it's handy when looking for spots in existing images, then applying the same corrections to a series of similar frames...
camera, dslr, k-5, k-5 ii, k-5 iis, k5, paper, pentax k-5, sensor, sensor for dust-like, test, test sensor
Is this what sensor dust looks like? 6BQ5 Pentax DSLR Discussion 3 06-20-2013 07:30 AM
What to buy to clean dust from sensor ? photoleet Pentax DSLR Discussion 21 11-04-2011 04:35 PM
What is the optimal size for a camera sensor? asw66 Photographic Technique 24 05-27-2009 10:36 AM
Dust particles JMR Post Your Photos! 2 08-07-2008 06:50 AM
What post-processing trick for visible sensor dust? bc_the_path Pentax DSLR Discussion 11 04-05-2007 05:57 AM
All times are GMT -7. The time now is 03:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
