12-21-2015, 10:32 PM   #1
picdude's Avatar
level
I have a K5II & a K5IIS I found this by accident but if you push info until the menu comes up. Then push info again then you get a level on the LCD. I thought they both did it but I just tried it and only the K5II does it.
12-21-2015, 10:37 PM   #2
Are they both on the latest firmware?
12-22-2015, 12:00 AM   #3
Tas
And the viewfinder?
QuoteOriginally posted by picdude Quote
Do you get the level indicators in the viewfinder of both cameras or just the K5II? According to the original K5 operating manual the electronic level is off by default. So it might be there but needs to be turned on in Rec mode 4 menu (assuming it's in the same place as the original K5).
12-22-2015, 10:24 AM   #4
blende8's Avatar
My K5IIs does show the level.
Of course you have to activate it in the menu first.
12-22-2015, 01:00 PM   #5
QuoteOriginally posted by Tas Quote
The original poster said the LCD which is NOT the viewfinder. You can get the same thing on the K5
12-22-2015, 07:14 PM   #6
Tas
Yep
QuoteOriginally posted by MikeD Quote
Hi Mike, I was asking if the OP could see them in the viewfinder, however I ommitted to add 'as well' so he knew I meant to also check for the level indicator in the viewfinder.
Either way, I think this issue is sorted if he turns on the level indicator in the menu. It will then appear on the LCD and in the viewfinder.
12-24-2015, 12:29 PM   #7
Good to know thanks
12-29-2015, 07:12 PM   #8
picdude's Avatar
QuoteOriginally posted by robthebloke Quote
Yes 1.07
---------- Post added 12-29-15 at 09:16 PM ----------
I forgot this part it's a different level than the one I get if I turn the level on.
The one I get pushing the info button twice has a circle in the middle of the lcd.
12-30-2015, 12:59 AM   #9
blende8's Avatar
So you still have the problem?
01-05-2016, 05:01 PM   #10
picdude's Avatar
QuoteOriginally posted by blende8 Quote
I don't think it's a problem. I just thought you guys may want to know about it.
01-06-2016, 12:13 AM   #11
blende8's Avatar
But the K5IIs does show the level.
01-14-2016, 06:42 PM   #12
picdude's Avatar
I did have the level turned off on that body. But turned on they both have the level pushing info and then info again.
camera, dslr, info, k-5, k-5 ii, k-5 iis, k5, k5ii, level, pentax k-5
Waist-level shooting Paul the Sunman Photographic Technique 12 08-08-2015 11:57 AM
Horizontal level robhau30 Troubleshooting and Beginner Help 15 07-16-2014 01:25 PM
Awesome low level flying in an F-18 (cockpit view) jogiba General Talk 4 09-07-2012 09:30 AM
Spirit Level. This has to be the deal of the week. Ed in GA Pentax Camera and Field Accessories 6 02-01-2008 09:35 AM
All times are GMT -7. The time now is 05:36 PM. | See also: NikonForums.com, part of our network of photo forums!
