Originally posted by Not a Number I never let alcohol near my camera or optical gear - it reacts with too many of the materials used in them.
There's probably no way to clean the staining without damaging the surface of the screen.
Fibers and dust may be on the pentaprism or between the screen and pentaprism. If you cleaned the area under the screen with a cloth or tissue the fibers may have gotten caught on edges or seals. The only way to remove these is to blow out as much as you can with a lens blower and then pick them out. Either with micro fine tweezers or an adhesive stick like the speck grabber mentioned above.
If for some reason you need to clean a screen I use water and just a touch of either pure soap (Ivory) or a mild dish soap and rinse with distilled water. Blot dry on a lint-less cloth or better yet blow dry with a lens blower. Never rub the surface. Always hold the screen by the tabs.
that's what I think, there can be some dust and fibers in the prism that fall down on the FS when set. Anyway it is on the FS otherwise I will see them blured, but I see them very sharply, so they are on the mate surface (top inner side) of the FS. Sadly my room is not a laboratory dust free room, and I don't have that so I'll have to find a trick to clean it, put a mask on it and set it fast so nothing goes on it... I'll see.
Ethylic pure 90% alcohol with 10% distilated water don't hurt stuff as far as I've tested, but once I used domestic methanol and this is bad.
