07-19-2016, 09:01 AM   #1
K5 Exposure Adjust Button Sticking
Recently my K5 exposure adjust button has been sticking. When I press it, the exposure adjust function occurs as it should, but when I press it again to turn it off, the exposure adjust function remains on, which then prevents me from adjusting the aperture using the rear wheel. I can fiddle with the button a bit and get it to return to normal but that of course is not fixing the problem, and it will stick in the "on" position again later. It appears the problem is purely mechanical in nature in that the button is just sticking in the down ("on") position. When I get it unstuck, the camera performs correctly. Has anyone else had this issue, or a similar button issue, and what did you do about it? Thanks. Glenn
07-19-2016, 09:25 AM   #2
I've had similar button problems on some electronics (not cameras). If I feel like the problem is gunk, then I use a small amount of water around the button, press it a few times, and then dry it off with a q-tip or small tissue. I don't know if I'd do this to my camera, but since it's supposed to be weather sealed, it probably wouldn't do any damage especially if the device were off and you let it dry. Proceed at your own risk with this solution....
07-20-2016, 06:18 AM   #3
QuoteOriginally posted by automorphism Quote
Thanks, most probably it is something like that. I'll proceed with caution and give it a try.
09-13-2016, 02:45 AM   #4
QuoteOriginally posted by GlennG Quote
Exact same issue on mine. Just gently poured hottish water over, waited a few minutes and it fixed it after pressing it a few times it seems as good as new.
09-13-2016, 09:28 AM   #5
QuoteOriginally posted by tigershoot Quote
Exact same issue on mine. Just gently poured hottish water over, waited a few minutes and it fixed it.
Thanks for the good tip. I'll try that as well.
button, camera, dslr, exposure, exposure adjust button, function, k-5, k-5 ii, k-5 iis, k5, pentax k-5, position, press
Sticking AE-L button Rnovo Pentax DSLR Discussion 2 06-15-2016 05:11 AM
K-3 Exposure Button Stuck After Rain Exposure soroush Pentax K-3 13 03-24-2015 09:20 AM
Green Button adjust only shutter? partynoparty Pentax K-5 7 09-15-2014 01:18 AM
k10d - can i adjust green-button-exposure measuring? teson Pentax DSLR Discussion 9 07-07-2010 08:39 AM
ME Super shutter button sticking? oinkely Pentax Film SLR Discussion 3 03-01-2009 01:51 PM
All times are GMT -7. The time now is 05:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
