Originally posted by MrB1 Thank you for those interesting points, Brian. It then begs the question - what is the point of applying EC in Manual Mode, when one can simply adjust whichever parameter(s) one desires, to compensate for lighting that might be fooling the meter? Are there scenarios where setting EC in Manual Mode is more useful than applying suitable manual adjustments?
Bookkeeping- you might prefer to dial in +1EV then zero the meter as opposed to setting the meter to +1 all day (for example). As you say, there's no real difference in how the camera operates here, but one way or the other might be easier for a given photographer's brain.
The Green Button - in M mode the Green Button will respect the EV compensation.
P-TTL Flash - EV comp. seems to adjust this as well (I've only tested with the pop-up, I've no other P-TTL flash).
Honestly, I never use EV comp in Manual and I wouldn't mind a menu setting to disable it. When I first got my k5iis I spent an afternoon wondering why the heck the meter was always consistently off by over a stop. Then I realized I had accidentally set the EV comp in M mode, which my previous camera didn't allow.
